I did a fresh install of newest coreelec (amlogic.arm 9.0.1). If I can remember correctly there was no autostart.sh at beginning, so I created one to get rid of this heartbeat for my Odroid C2.
/storage/.config/autostart.sh created (utf-8 encoded).
#!/bin/sh
echo none > /sys/class/leds/blue:heartbeat/trigger
If I execute the echo manually, it works. However, it seems that the autostart.sh is not executed, because the led is still blinking after reboot ![]()
What is the issue? Is there a log to see if something went wrong?
P.S. systemctl status kodi-autostart.service -l --no-pager
kodi-autostart.service - Kodi user autostart script
Loaded: loaded (/storage/.config/system.d/kodi-autostart.service; disabled; vendor preset: disabled)
Active: active (exited) since Fri 2018-06-22 13:11:51 CEST; 9 months 11 days ago
Main PID: 2614 (code=exited, status=0/SUCCESS)
Memory: 0B
CGroup: /system.slice/kodi-autostart.serviceJun 22 13:11:51 HTPC systemd[1]: Starting Kodi user autostart script…
Jun 22 13:11:51 HTPC systemd[1]: Started Kodi user autostart script.
Thanks!
