I’m using entware to install esphome on CE.
It installed successfully but wont start after rebooting.
In the instructions for installation it is said to issue this command if esphome is not found after installation
export PATH=$PATH:$HOME/.local/bin
and that To set this permanently, you can run
echo 'export PATH=$PATH:$HOME/.local/bin' >> $HOME/.bashrc
but this is not working in my case after a reboot.
I also tried adding the following to my autostart…
sleep 20
but that didnt work either.
Any suggestions please?
