I have an SSD1311 oled installed on Coreelec 9.2.7, Odroid C4.
To use this type of controller, I have an hd44780 driver which is compiled on 64bit.
When I try with included lcdproc addon, it says something about 64bit header. So my understanding is the included addon is for 32bit.
Is any 64bit lcdproc addon available?
I tested with a minimal ubuntu and after installing lcdproc oled works. I try to copy LCDd executable from ubuntu to Coreelec but it not works.
Is any other solution?
Thanks.
LE Solved by replacing the driver.
