hi, now I tried some things and it still doesn’t work so I’ll ask you:
meson ir is working for me in the old kernel builds but not in the ng-build (9.2.5). I wrote back the backup from the old build and confirmed that the rc_maps cfg and corresponding keymap were still there.
ir-keytable -t (after stopping kodi and eventlircd) sees nothing.
amremote (remote.conf) works but sadly then kodi doesn’t respect my mapping in keyboard.xml (I don’t know why and I might investigate this further but now I’m mostly interested in getting meson ir back to work.)
I see some differences in dmesg that seem relevant:
Because that one works just fine on my NexBox A95X-B7N (S90X) (CE-ng device), which uses the same remote as the NexBox A95X-A95 (S905) (non-ng device).
it also works just fine for me in the non-ng build on the same box.
I don’t think the problem is with the keymap, I think it’s more fundamental, as even ir-keytable -t can’t see anything. but then again, what do I know…
would further logs help? I didn’t find anything related to the remote in the kodi (debug) logs but did in dmesg, so that’s what I posted. from the snippets above it seems as if the ng-build fails to “initialize the protocol handlers”.
but why or whether that’s even the problem, I don’t know and there I’m just out of my depth.
I think right now I’m using the AmRemote version on the NexBox. Let me check and if yes, I’ll download and install the MesonIR version from the repo, this just to exclude a corrupted archive.
