[SOLVED] Odroid N2, CE 9.2.8 and DV fallback to HDR
Hi! Running CoreELEC 9.2.8 on Odroid N2 4GB. Works just fine. I do a setup (remote) for my friend, so I wonder if N2 with 9.2.8 can play DV with fallback to HDR/HDR10(+)? We don’t need DV, just fallback to any of the HDR formats that are supported.
I know DV is not supported, and we don’t need it.
It´s EOL, no more support.
DV files will play in HDR if supported, check with mediainfo
Video
Format                                   : HEVC
Format/Info                              : High Efficiency Video Coding
Format profile                           : Main 10@L5@High
HDR format                               : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible
Codec ID                                 : V_MPEGH/ISO/HEVC
Yes, I know its EOL, but works perfectly.
I know the file needs to have HDR version able to fallback, but if that is present, N2 will play it back fine, correct?
Don´t know about CE 9.2.8
My N2 ist running CE 20.2, playback works
My N2+ is running CE 19.5, playback works
CE 19.5 can be a direct update over 9.2.8 from inside CoreELEC on N2?
First step = backup
You can try direct upgrade 9.2.8 to 19.5
But:
Fresh install is recommended
Recommendation = stable CE 20.2
Thanks!
Did an update to 19.5 it looks it went fine. Will check and see if everything works. Can’t do remote fresh install atm.
Thanks for your support. Will maybe check out 20.02 later.
