Hi guys,
I have set up the CEC so I can power off and on the Odroid N2 (CoreELEC 9.2.2) together with my TV Samsung le46c650, which is connected via Denon X1000. (N2 -> (HDMI) -> Denon -> (HDMI) -> TV). But I would like to only power N2 off together with TV. I do not want to power it on always when I power on TV (I use N2 rarely, so I do not want useless consume the energy). I tried several options in Settings/System/Input/Peripherals/CEC Adapter, but without success.
- Do you know by chance if this option would be possible?
The second part of this issue is how to power N2 on.
2A. Is it possible to customize (keymaps/remote.xml) my remote control with dedicated button to power the N2 on? Then it need to be in suspend mode or completely shutdown?
2B. Is it possible to power on the N2 somehow with Kore app? I tried to wake it up, but without a success.
Basically what is the difference If I shutdown the N2 or suspend it when I would use the option in Settings/System/Input/Peripherals/CEC Adapter? I feel that the device is somehow warm even I do not use it, therefore I would like to tune the power on/off procedure.
- What is your recommendation/set-up, how you power on/off the N2 when using it sporadically?
