Greetings,
I installed CE 8.90.4, everything is great, but PVR Clients are not running.
When you try to remove it and reload it, it is not called as incompatible.
Best regards…
Greetings,
Best regards…
I have a WP2 pvr problem.Addons do not load pvr.
You need to clear your package cache and update repositories when reinstalling otherwise your device will install old version that is cached on your device.
Greetings,
Ok, now everything works.
But DVBViewer PVR client connects and disconnects, connects and disconnects, ie it enters the loop and performs the device gui-restart.
I just could not figure it out.
Best regards…
Looks like an issue with your tvheadend server.
Greetings,
https://forum.kodi.tv/showthread.php?tid=333116 .
Could you update it to version 3.6.2 for CE?
Best regards…
Done
Check for updates and it should appear.
I installed version 3.5.1.3 of the add-on, and it works fine, without problems …
Greetings,
The problem was solved with the latest version 3.6.2.3, thank you very much.
Best regards…
Greetings,
There is still a problem with the latest version of PVR DVBViewer Client.
https://drive.google.com/open?id=1KOrltQ5j9ifWUYg8-hqzA16IPBBBOJ5D
Best regards…
Greetings,
Yeah, like he said, 32KB didn’t matter. He works super.
Best regards…
Addons have been updated to latest revision in CE repo, update and there should be no issue.
