I have nighty 20190109 currently installed on my A95 (S905).
I installed screensaver add-on ‘Turn Off’.
When I set the screensaver display setting to CEC or DPMS (non-built in option) the TV will turn off after the time period selected passes. The same thing happens if I use the preview button.
However if a movie is paused the TV will not turn off. It only dims the picture just like you would see if Dim was the selected screen saver.
I also see the same behavior if I select ‘Black’ as the screen saver, so I don’t think the issue is specific to the ‘Turn Off’ add on.
Can anyone else confirm they are seeing this behavior, or does anyone know a work around to have the system shut off the TV via CEC or no-signal when media is left in a paused state?
I have been able to use this setup on other systems in the past, so I can’t see why it wouldn’t work here.
Thanks for any suggestions.
