[Solved] Tvheadend - Issue when switching channels
Hi there,
I’m a big fan of Coreelec, but unfortunatly i have problems with the Tvheadend addon.
When i start watching the first channel everything works fine, apart from small occasional stuttering.
But when i try to switch to another channel, the playback stops and buffers for a very long time.
When you are lucky, the playback comes back but only the audio and it sounds extremly distorted.
I can’t explain this error to me. Here you can find the logs: http://ix.io/2dni
The interesting part starts at 15:51. The channel “DMAX” works, but swiching to e.g. “WDR HD” doesn’t work anymore.
My box is the Vontar X96 Max + with the S905X3 SOC. I’m using the latest nightly.
Thanks in advance for your help :slight_smile:
Edit: I forgot to say that i’m using a USB DVB-C Tuner, the Silicon Labs Si2168.
It’s a MyGica T230 stick.
I know it’s a bit offtopic, but could somebody explain me, why my stick is only recognized as a DVB-C Stick when using the Crazycat drivers?
Using the Coreelec standard drivers, the stick is listed as a device, but only for DVB-T.
There are differences in the drivers that make it possible for the t230 to be recognized as dvb-c. It isn’t sometimes even advertised as dvb-c as you can read from here:
https://www.linuxtv.org/wiki/index.php/Geniatech_T230
Can you check what version of tvh server you’re using and can you paste part of the tvh server log (the one you can activate on the bottom right corner of tvh webui)?
I can run some tests as I own one of those sticks though I use it primarily in an old kernel device. I can’t do it until weekend, sorry.
Yes of course, don’t worry it’s not such a big problem for me. I can wait.
This is the version: “HTS Tvheadend 4.2.8-36 ~ CoreELEC Tvh-addon v9.2.121”
And here comes the log:
First channel had the issue with stuttering audio only, second worked more or less, third worked not at all.
Debugloglevel: aktiviert
2020-03-04 16:55:05.105 tbl-base: bat: 402MHz in DVB-C Netzwerk: invalid checksum (len 4036, errors 17)
2020-03-04 16:55:05.953 tbl-eit: eit: 402MHz in DVB-C Netzwerk: invalid checksum (len 568, errors 1013)
2020-03-04 16:55:05.953 tbl-base: nit: 402MHz in DVB-C Netzwerk: invalid checksum (len 1022, errors 235)
2020-03-04 16:55:05.994 http: 127.0.0.1: HTTP/1.1 HEAD /imagecache/151 -- 404
2020-03-04 16:55:05.997 http: 127.0.0.1: HTTP/1.1 HEAD /imagecache/133 -- 404
2020-03-04 16:55:06.000 http: 127.0.0.1: HTTP/1.1 HEAD /imagecache/207 -- 404
2020-03-04 16:55:06.002 http: 127.0.0.1: HTTP/1.1 HEAD /imagecache/143 -- 404
2020-03-04 16:55:06.005 http: 127.0.0.1: HTTP/1.1 HEAD /imagecache/63 -- 404
2020-03-04 16:55:06.008 http: 127.0.0.1: HTTP/1.1 HEAD /imagecache/149 -- 404
2020-03-04 16:55:06.010 http: 127.0.0.1: HTTP/1.1 HEAD /imagecache/48 -- 404
2020-03-04 16:55:06.013 http: 127.0.0.1: HTTP/1.1 HEAD /imagecache/134 -- 404
2020-03-04 16:55:06.013 http: 127.0.0.1: HTTP/1.1 HEAD /imagecache/151 -- 404
2020-03-04 16:55:06.015 http: 127.0.0.1: HTTP/1.1 HEAD /imagecache/51 -- 404
2020-03-04 16:55:06.018 http: 127.0.0.1: HTTP/1.1 HEAD /imagecache/137 -- 404
2020-03-04 16:55:06.018 http: 127.0.0.1: HTTP/1.1 HEAD /imagecache/133 -- 404
2020-03-04 16:55:06.022 http: 127.0.0.1: HTTP/1.1 HEAD /imagecache/207 -- 404
2020-03-04 16:55:06.025 http: 127.0.0.1: HTTP/1.1 HEAD /imagecache/143 -- 404
2020-03-04 16:55:06.028 http: 127.0.0.1: HTTP/1.1 HEAD /imagecache/63 -- 404
2020-03-04 16:55:06.031 http: 127.0.0.1: HTTP/1.1 HEAD /imagecache/149 -- 404
2020-03-04 16:55:06.034 http: 127.0.0.1: HTTP/1.1 HEAD /imagecache/48 -- 404
2020-03-04 16:55:06.037 http: 127.0.0.1: HTTP/1.1 HEAD /imagecache/134 -- 404
2020-03-04 16:55:06.040 http: 127.0.0.1: HTTP/1.1 HEAD /imagecache/51 -- 404
2020-03-04 16:55:08.052 tbl-base: sdt: 402MHz in DVB-C Netzwerk: invalid checksum (len 573, errors 80)
2020-03-04 16:55:10.529 mpegts: 330MHz in DVB-C Netzwerk - tuning on Silicon Labs Si2168 #0 : DVB-C #0
2020-03-04 16:55:10.530 subscription: 0003: "epggrab" unsubscribing
2020-03-04 16:55:10.531 subscription: 0005: "127.0.0.1 [  | Kodi Media Center ]" subscribing on channel "Das Erste HD", weight: 150, adapter: "Silicon Labs Si2168 #0 : DVB-C #0", network: "DVB-C Netzwerk", mux: "330MHz", provider: "ARD", service: "Das Erste HD", profile="htsp", hostname="127.0.0.1", username="127.0.0.1", client="Kodi Media Center"
2020-03-04 16:55:10.605 http: 127.0.0.1: HTTP/1.1 HEAD /imagecache/151 -- 404
2020-03-04 16:55:10.609 http: 127.0.0.1: HTTP/1.1 HEAD /imagecache/133 -- 404
2020-03-04 16:55:10.611 http: 127.0.0.1: HTTP/1.1 HEAD /imagecache/207 -- 404
2020-03-04 16:55:10.747 TS: DVB-C Netzwerk/330MHz/Das Erste HD Transport error indicator (total 1)
2020-03-04 16:55:10.838 tbl-eit: eit: 330MHz in DVB-C Netzwerk: invalid checksum (len 545, errors 1)
2020-03-04 16:55:10.838 tbl-base: nit: 330MHz in DVB-C Netzwerk: invalid checksum (len 816, errors 1)
2020-03-04 16:55:10.862 mpegts: mux 346MHz in DVB-C Netzwerk old params DVB-C freq 346000000 sym 6900000 mod QAM/256 fec NONE ds 0 plp -1 (00020000)
2020-03-04 16:55:10.862 mpegts: mux 346MHz in DVB-C Netzwerk new params DVB-C freq 346000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020000)
2020-03-04 16:55:11.073 mpegts: mux 402MHz in DVB-C Netzwerk old params DVB-C freq 402000000 sym 6900000 mod QAM/256 fec NONE ds 0 plp -1 (00020000)
2020-03-04 16:55:11.073 mpegts: mux 402MHz in DVB-C Netzwerk new params DVB-C freq 402000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020000)
2020-03-04 16:55:11.074 mpegts: mux 410MHz in DVB-C Netzwerk old params DVB-C freq 410000000 sym 6900000 mod QAM/256 fec NONE ds 0 plp -1 (00020000)
2020-03-04 16:55:11.074 mpegts: mux 410MHz in DVB-C Netzwerk new params DVB-C freq 410000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020000)
2020-03-04 16:55:11.074 mpegts: mux 418MHz in DVB-C Netzwerk old params DVB-C freq 418000000 sym 6900000 mod QAM/256 fec NONE ds 0 plp -1 (00020000)
2020-03-04 16:55:11.074 mpegts: mux 418MHz in DVB-C Netzwerk new params DVB-C freq 418000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020000)
2020-03-04 16:55:11.074 mpegts: mux 426MHz in DVB-C Netzwerk old params DVB-C freq 426000000 sym 6900000 mod QAM/256 fec NONE ds 0 plp -1 (00020000)
2020-03-04 16:55:11.074 mpegts: mux 426MHz in DVB-C Netzwerk new params DVB-C freq 426000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020000)
2020-03-04 16:55:11.074 mpegts: mux 434MHz in DVB-C Netzwerk old params DVB-C freq 434000000 sym 6900000 mod QAM/256 fec NONE ds 0 plp -1 (00020000)
2020-03-04 16:55:11.074 mpegts: mux 434MHz in DVB-C Netzwerk new params DVB-C freq 434000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020000)
2020-03-04 16:55:11.074 mpegts: mux 442MHz in DVB-C Netzwerk old params DVB-C freq 442000000 sym 6900000 mod QAM/256 fec NONE ds 0 plp -1 (00020000)
2020-03-04 16:55:11.074 mpegts: mux 442MHz in DVB-C Netzwerk new params DVB-C freq 442000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020000)
2020-03-04 16:55:11.074 mpegts: mux 450MHz in DVB-C Netzwerk old params DVB-C freq 450000000 sym 6900000 mod QAM/256 fec NONE ds 0 plp -1 (00020000)
2020-03-04 16:55:11.074 mpegts: mux 450MHz in DVB-C Netzwerk new params DVB-C freq 450000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020000)
2020-03-04 16:55:11.260 tbl-base: pmt: 330MHz in DVB-C Netzwerk: invalid checksum (len 175, errors 1)
2020-03-04 16:55:11.330 mpegts: mux 458MHz in DVB-C Netzwerk old params DVB-C freq 458000000 sym 6900000 mod QAM/256 fec NONE ds 0 plp -1 (00020000)
2020-03-04 16:55:11.330 mpegts: mux 458MHz in DVB-C Netzwerk new params DVB-C freq 458000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020000)
2020-03-04 16:55:11.541 TS: DVB-C Netzwerk/330MHz/Das Erste HD: H264 @ #6010 Continuity counter error (total 1)
2020-03-04 16:55:11.553 TS: DVB-C Netzwerk/330MHz/Das Erste HD: TELETEXT @ #6030 Continuity counter error (total 1)
2020-03-04 16:55:11.553 TS: DVB-C Netzwerk/330MHz/Das Erste HD: AC3 @ #6022 Continuity counter error (total 1)
2020-03-04 16:55:11.566 TS: DVB-C Netzwerk/330MHz/Das Erste HD: MPEG2AUDIO @ #6020 Continuity counter error (total 1)
2020-03-04 16:55:11.630 TS: DVB-C Netzwerk/330MHz/Das Erste HD: MPEG2AUDIO @ #6021 Continuity counter error (total 1)
2020-03-04 16:55:11.666 mpegts: mux 394MHz in DVB-C Netzwerk old params DVB-C freq 394000000 sym 6900000 mod QAM/64 fec NONE ds 0 plp -1 (00020040)
2020-03-04 16:55:11.666 mpegts: mux 394MHz in DVB-C Netzwerk new params DVB-C freq 394000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020040)
2020-03-04 16:55:11.666 mpegts: mux 370MHz in DVB-C Netzwerk old params DVB-C freq 370000000 sym 6900000 mod QAM/64 fec NONE ds 0 plp -1 (00020040)
2020-03-04 16:55:11.666 mpegts: mux 370MHz in DVB-C Netzwerk new params DVB-C freq 370000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020040)
2020-03-04 16:55:11.666 mpegts: mux 362MHz in DVB-C Netzwerk old params DVB-C freq 362000000 sym 6900000 mod QAM/64 fec NONE ds 0 plp -1 (00020040)
2020-03-04 16:55:11.666 mpegts: mux 362MHz in DVB-C Netzwerk new params DVB-C freq 362000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020040)
2020-03-04 16:55:11.890 mpegts: mux 378MHz in DVB-C Netzwerk old params DVB-C freq 378000000 sym 6900000 mod QAM/64 fec NONE ds 0 plp -1 (00020040)
2020-03-04 16:55:11.890 mpegts: mux 378MHz in DVB-C Netzwerk new params DVB-C freq 378000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020040)
2020-03-04 16:55:11.890 mpegts: mux 386MHz in DVB-C Netzwerk old params DVB-C freq 386000000 sym 6900000 mod QAM/64 fec NONE ds 0 plp -1 (00020040)
2020-03-04 16:55:11.890 mpegts: mux 386MHz in DVB-C Netzwerk new params DVB-C freq 386000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020040)
2020-03-04 16:55:11.890 mpegts: mux 354MHz in DVB-C Netzwerk old params DVB-C freq 354000000 sym 6900000 mod QAM/64 fec NONE ds 0 plp -1 (00020040)
2020-03-04 16:55:11.890 mpegts: mux 354MHz in DVB-C Netzwerk new params DVB-C freq 354000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020040)
2020-03-04 16:55:12.604 TS: DVB-C Netzwerk/330MHz/Das Erste HD: DVBSUB @ #6031 Continuity counter error (total 1)
2020-03-04 16:55:14.717 tbl-base: cat: 330MHz in DVB-C Netzwerk: invalid checksum (len 36, errors 1)
2020-03-04 16:55:15.152 TS: DVB-C Netzwerk/330MHz/Das Erste HD: H264 @ #6010 Corrupted PES header (errors 1)
2020-03-04 16:55:15.343 tbl-base: sdt: 330MHz in DVB-C Netzwerk: invalid checksum (len 140, errors 1)
2020-03-04 16:55:18.957 tsfix: The timediff for TELETEXT is big (673400), using current dts
2020-03-04 16:55:18.958 tsfix: The timediff for MPEG2AUDIO is big (672069), using current dts
2020-03-04 16:55:18.959 tsfix: The timediff for MPEG2AUDIO is big (516549), using current dts
2020-03-04 16:55:18.967 tsfix: transport stream MPEG2AUDIO, DTS discontinuity. DTS = 397440, last = 304560
2020-03-04 16:55:18.973 tsfix: transport stream MPEG2AUDIO, DTS discontinuity. DTS = 509760, last = 408240
2020-03-04 16:55:19.702 tsfix: transport stream MPEG2AUDIO, DTS discontinuity. DTS = 794880, last = 671760
2020-03-04 16:55:20.803 TS: DVB-C Netzwerk/330MHz/Das Erste HD Transport error indicator (total 13)
2020-03-04 16:55:20.829 http: 127.0.0.1: HTTP/1.1 HEAD /imagecache/151 -- 404
2020-03-04 16:55:20.891 tbl-base: nit: 330MHz in DVB-C Netzwerk: invalid checksum (len 1017, errors 35)
2020-03-04 16:55:20.936 tbl-eit: eit: 330MHz in DVB-C Netzwerk: invalid checksum (len 677, errors 55)
2020-03-04 16:55:21.247 tsfix: transport stream MPEG2AUDIO, DTS discontinuity. DTS = 777600, last = 680400
2020-03-04 16:55:21.247 tsfix: transport stream MPEG2AUDIO, DTS discontinuity. DTS = 933120, last = 822960
2020-03-04 16:55:21.539 TS: DVB-C Netzwerk/330MHz/Das Erste HD: H264 @ #6010 Continuity counter error (total 19920)
2020-03-04 16:55:21.566 TS: DVB-C Netzwerk/330MHz/Das Erste HD: MPEG2AUDIO @ #6020 Continuity counter error (total 133)
2020-03-04 16:55:21.566 TS: DVB-C Netzwerk/330MHz/Das Erste HD: AC3 @ #6022 Continuity counter error (total 235)
2020-03-04 16:55:21.579 TS: DVB-C Netzwerk/330MHz/Das Erste HD: TELETEXT @ #6030 Continuity counter error (total 93)
2020-03-04 16:55:21.815 TS: DVB-C Netzwerk/330MHz/Das Erste HD: MPEG2AUDIO @ #6021 Continuity counter error (total 116)
2020-03-04 16:55:22.193 tbl-base: pmt: 330MHz in DVB-C Netzwerk: invalid checksum (len 175, errors 3)
2020-03-04 16:55:23.701 tsfix: transport stream H264, DTS discontinuity. DTS = 592000, last = 160000
2020-03-04 16:55:24.123 tsfix: transport stream MPEG2AUDIO, DTS discontinuity. DTS = 1036800, last = 896400
2020-03-04 16:55:24.916 tbl-base: pat: 330MHz in DVB-C Netzwerk: invalid checksum (len 36, errors 1)
2020-03-04 16:55:25.047 TS: DVB-C Netzwerk/330MHz/Das Erste HD: DVBSUB @ #6031 Continuity counter error (total 14)
2020-03-04 16:55:25.760 tsfix: transport stream MPEG2AUDIO, DTS discontinuity. DTS = 1339200, last = 1168560
2020-03-04 16:55:26.234 tsfix: transport stream H264, DTS discontinuity. DTS = 795400, last = 592000
2020-03-04 16:55:27.101 tsfix: transport stream MPEG2AUDIO, DTS discontinuity. DTS = 1460160, last = 1354320
2020-03-04 16:55:27.388 tsfix: transport stream MPEG2AUDIO, DTS discontinuity. DTS = 1330560, last = 1233360
2020-03-04 16:55:27.951 TS: DVB-C Netzwerk/330MHz/Das Erste HD: H264 @ #6010 Corrupted PES header (errors 3)
2020-03-04 16:55:28.832 tsfix: transport stream MPEG2AUDIO, DTS discontinuity. DTS = 1615680, last = 1468800
2020-03-04 16:55:29.308 tsfix: transport stream MPEG2AUDIO, DTS discontinuity. DTS = 1503360, last = 1384560
2020-03-04 16:55:30.685 tsfix: transport stream H264, DTS discontinuity. DTS = 1209400, last = 889000
2020-03-04 16:55:30.859 tbl-base: cat: 330MHz in DVB-C Netzwerk: invalid checksum (len 36, errors 3)
2020-03-04 16:55:30.921 tbl-base: nit: 330MHz in DVB-C Netzwerk: invalid checksum (len 998, errors 83)
2020-03-04 16:55:30.936 tbl-eit: eit: 330MHz in DVB-C Netzwerk: invalid checksum (len 576, errors 115)
2020-03-04 16:55:31.125 TS: DVB-C Netzwerk/330MHz/Das Erste HD Transport error indicator (total 38)
2020-03-04 16:55:31.530 TS: DVB-C Netzwerk/330MHz/Das Erste HD: H264 @ #6010 Continuity counter error (total 39704)
2020-03-04 16:55:31.628 TS: DVB-C Netzwerk/330MHz/Das Erste HD: MPEG2AUDIO @ #6020 Continuity counter error (total 253)
2020-03-04 16:55:31.688 TS: DVB-C Netzwerk/330MHz/Das Erste HD: AC3 @ #6022 Continuity counter error (total 472)
2020-03-04 16:55:31.714 TS: DVB-C Netzwerk/330MHz/Das Erste HD: TELETEXT @ #6030 Continuity counter error (total 164)
2020-03-04 16:55:31.825 TS: DVB-C Netzwerk/330MHz/Das Erste HD: MPEG2AUDIO @ #6021 Continuity counter error (total 242)
2020-03-04 16:55:33.048 tsfix: transport stream MPEG2AUDIO, DTS discontinuity. DTS = 1840320, last = 1639440
2020-03-04 16:55:33.535 tsfix: transport stream MPEG2AUDIO, DTS discontinuity. DTS = 2039040, last = 1816560
2020-03-04 16:55:34.255 subscription: 0005: "127.0.0.1 [  | Kodi Media Center ]" unsubscribing from "Das Erste HD", hostname="127.0.0.1", username="127.0.0.1", client="Kodi Media Center"
2020-03-04 16:55:34.526 http: 127.0.0.1: HTTP/1.1 HEAD /imagecache/151 -- 404
2020-03-04 16:55:35.174 mpegts: 330MHz in DVB-C Netzwerk - tuning on Silicon Labs Si2168 #0 : DVB-C #0
2020-03-04 16:55:35.175 subscription: 0007: "epggrab" subscribing to mux "330MHz", weight: 4, adapter: "Silicon Labs Si2168 #0 : DVB-C #0", network: "DVB-C Netzwerk", service: "Raw PID Subscription"
2020-03-04 16:55:35.515 tbl-base: nit: 330MHz in DVB-C Netzwerk: invalid checksum (len 998, errors 1)
2020-03-04 16:55:35.515 tbl-eit: eit: 330MHz in DVB-C Netzwerk: invalid checksum (len 657, errors 1)
2020-03-04 16:55:35.550 http: 127.0.0.1: HTTP/1.1 HEAD /imagecache/133 -- 404
2020-03-04 16:55:35.919 mpegts: mux 378MHz in DVB-C Netzwerk old params DVB-C freq 378000000 sym 6900000 mod QAM/64 fec NONE ds 0 plp -1 (00020040)
2020-03-04 16:55:35.919 mpegts: mux 378MHz in DVB-C Netzwerk new params DVB-C freq 378000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020040)
2020-03-04 16:55:35.919 mpegts: mux 386MHz in DVB-C Netzwerk old params DVB-C freq 386000000 sym 6900000 mod QAM/64 fec NONE ds 0 plp -1 (00020040)
2020-03-04 16:55:35.919 mpegts: mux 386MHz in DVB-C Netzwerk new params DVB-C freq 386000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020040)
2020-03-04 16:55:35.919 mpegts: mux 354MHz in DVB-C Netzwerk old params DVB-C freq 354000000 sym 6900000 mod QAM/64 fec NONE ds 0 plp -1 (00020040)
2020-03-04 16:55:35.919 mpegts: mux 354MHz in DVB-C Netzwerk new params DVB-C freq 354000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020040)
2020-03-04 16:55:35.966 http: 127.0.0.1: HTTP/1.1 HEAD /imagecache/207 -- 404
2020-03-04 16:55:36.212 http: 127.0.0.1: HTTP/1.1 HEAD /imagecache/143 -- 404
2020-03-04 16:55:36.414 http: 127.0.0.1: HTTP/1.1 HEAD /imagecache/63 -- 404
2020-03-04 16:55:36.666 http: 127.0.0.1: HTTP/1.1 HEAD /imagecache/149 -- 404
2020-03-04 16:55:36.773 tbl-base: pat: 330MHz in DVB-C Netzwerk: invalid checksum (len 277, errors 1)
2020-03-04 16:55:36.917 http: 127.0.0.1: HTTP/1.1 HEAD /imagecache/48 -- 404
2020-03-04 16:55:36.946 mpegts: mux 458MHz in DVB-C Netzwerk old params DVB-C freq 458000000 sym 6900000 mod QAM/256 fec NONE ds 0 plp -1 (00020000)
2020-03-04 16:55:36.946 mpegts: mux 458MHz in DVB-C Netzwerk new params DVB-C freq 458000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020000)
2020-03-04 16:55:37.077 http: 127.0.0.1: HTTP/1.1 HEAD /imagecache/134 -- 404
2020-03-04 16:55:37.082 http: 127.0.0.1: HTTP/1.1 HEAD /imagecache/137 -- 404
2020-03-04 16:55:37.310 http: 127.0.0.1: HTTP/1.1 HEAD /imagecache/51 -- 404
2020-03-04 16:55:37.857 mpegts: mux 346MHz in DVB-C Netzwerk old params DVB-C freq 346000000 sym 6900000 mod QAM/256 fec NONE ds 0 plp -1 (00020000)
2020-03-04 16:55:37.857 mpegts: mux 346MHz in DVB-C Netzwerk new params DVB-C freq 346000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020000)
2020-03-04 16:55:38.546 mpegts: 394MHz in DVB-C Netzwerk - tuning on Silicon Labs Si2168 #0 : DVB-C #0
2020-03-04 16:55:38.548 subscription: 0007: "epggrab" unsubscribing
2020-03-04 16:55:38.548 subscription: 0009: "127.0.0.1 [  | Kodi Media Center ]" subscribing on channel "RTL Television", weight: 150, adapter: "Silicon Labs Si2168 #0 : DVB-C #0", network: "DVB-C Netzwerk", mux: "394MHz", provider: "Unitymedia", service: "RTL Television", profile="htsp", hostname="127.0.0.1", username="127.0.0.1", client="Kodi Media Center"
2020-03-04 16:55:38.898 mpegts: mux 378MHz in DVB-C Netzwerk old params DVB-C freq 378000000 sym 6900000 mod QAM/64 fec NONE ds 0 plp -1 (00020040)
2020-03-04 16:55:38.898 mpegts: mux 378MHz in DVB-C Netzwerk new params DVB-C freq 378000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020040)
2020-03-04 16:55:38.898 mpegts: mux 386MHz in DVB-C Netzwerk old params DVB-C freq 386000000 sym 6900000 mod QAM/64 fec NONE ds 0 plp -1 (00020040)
2020-03-04 16:55:38.898 mpegts: mux 386MHz in DVB-C Netzwerk new params DVB-C freq 386000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020040)
2020-03-04 16:55:38.898 mpegts: mux 354MHz in DVB-C Netzwerk old params DVB-C freq 354000000 sym 6900000 mod QAM/64 fec NONE ds 0 plp -1 (00020040)
2020-03-04 16:55:38.898 mpegts: mux 354MHz in DVB-C Netzwerk new params DVB-C freq 354000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020040)
2020-03-04 16:55:39.357 mpegts: mux 346MHz in DVB-C Netzwerk old params DVB-C freq 346000000 sym 6900000 mod QAM/256 fec NONE ds 0 plp -1 (00020000)
2020-03-04 16:55:39.358 mpegts: mux 346MHz in DVB-C Netzwerk new params DVB-C freq 346000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020000)
2020-03-04 16:55:39.428 tsfix: The timediff for TELETEXT is big (3426473922), using current dts
2020-03-04 16:55:39.576 mpegts: mux 402MHz in DVB-C Netzwerk old params DVB-C freq 402000000 sym 6900000 mod QAM/256 fec NONE ds 0 plp -1 (00020000)
2020-03-04 16:55:39.576 mpegts: mux 402MHz in DVB-C Netzwerk new params DVB-C freq 402000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020000)
2020-03-04 16:55:39.576 mpegts: mux 410MHz in DVB-C Netzwerk old params DVB-C freq 410000000 sym 6900000 mod QAM/256 fec NONE ds 0 plp -1 (00020000)
2020-03-04 16:55:39.576 mpegts: mux 410MHz in DVB-C Netzwerk new params DVB-C freq 410000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020000)
2020-03-04 16:55:39.576 mpegts: mux 418MHz in DVB-C Netzwerk old params DVB-C freq 418000000 sym 6900000 mod QAM/256 fec NONE ds 0 plp -1 (00020000)
2020-03-04 16:55:39.576 mpegts: mux 418MHz in DVB-C Netzwerk new params DVB-C freq 418000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020000)
2020-03-04 16:55:39.576 mpegts: mux 426MHz in DVB-C Netzwerk old params DVB-C freq 426000000 sym 6900000 mod QAM/256 fec NONE ds 0 plp -1 (00020000)
2020-03-04 16:55:39.576 mpegts: mux 426MHz in DVB-C Netzwerk new params DVB-C freq 426000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020000)
2020-03-04 16:55:39.576 mpegts: mux 434MHz in DVB-C Netzwerk old params DVB-C freq 434000000 sym 6900000 mod QAM/256 fec NONE ds 0 plp -1 (00020000)
2020-03-04 16:55:39.576 mpegts: mux 434MHz in DVB-C Netzwerk new params DVB-C freq 434000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020000)
2020-03-04 16:55:39.576 mpegts: mux 442MHz in DVB-C Netzwerk old params DVB-C freq 442000000 sym 6900000 mod QAM/256 fec NONE ds 0 plp -1 (00020000)
2020-03-04 16:55:39.576 mpegts: mux 442MHz in DVB-C Netzwerk new params DVB-C freq 442000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020000)
2020-03-04 16:55:39.576 mpegts: mux 450MHz in DVB-C Netzwerk old params DVB-C freq 450000000 sym 6900000 mod QAM/256 fec NONE ds 0 plp -1 (00020000)
2020-03-04 16:55:39.576 mpegts: mux 450MHz in DVB-C Netzwerk new params DVB-C freq 450000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020000)
2020-03-04 16:55:39.820 mpegts: mux 458MHz in DVB-C Netzwerk old params DVB-C freq 458000000 sym 6900000 mod QAM/256 fec NONE ds 0 plp -1 (00020000)
2020-03-04 16:55:39.820 mpegts: mux 458MHz in DVB-C Netzwerk new params DVB-C freq 458000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020000)
2020-03-04 16:55:40.168 mpegts: mux 394MHz in DVB-C Netzwerk old params DVB-C freq 394000000 sym 6900000 mod QAM/64 fec NONE ds 0 plp -1 (00020040)
2020-03-04 16:55:40.168 mpegts: mux 394MHz in DVB-C Netzwerk new params DVB-C freq 394000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020040)
2020-03-04 16:55:40.168 mpegts: mux 370MHz in DVB-C Netzwerk old params DVB-C freq 370000000 sym 6900000 mod QAM/64 fec NONE ds 0 plp -1 (00020040)
2020-03-04 16:55:40.168 mpegts: mux 370MHz in DVB-C Netzwerk new params DVB-C freq 370000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020040)
2020-03-04 16:55:40.168 mpegts: mux 362MHz in DVB-C Netzwerk old params DVB-C freq 362000000 sym 6900000 mod QAM/64 fec NONE ds 0 plp -1 (00020040)
2020-03-04 16:55:40.168 mpegts: mux 362MHz in DVB-C Netzwerk new params DVB-C freq 362000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020040)
2020-03-04 16:55:42.650 TS: DVB-C Netzwerk/394MHz/RTL Television: MPEG2VIDEO @ #523 Continuity counter error (total 1)
2020-03-04 16:55:42.650 TS: DVB-C Netzwerk/394MHz/RTL Television: TELETEXT @ #528 Continuity counter error (total 1)
2020-03-04 16:55:42.669 TS: DVB-C Netzwerk/394MHz/RTL Television: AC3 @ #525 Continuity counter error (total 1)
2020-03-04 16:55:42.682 TS: DVB-C Netzwerk/394MHz/RTL Television: MPEG2AUDIO @ #524 Continuity counter error (total 1)
2020-03-04 16:55:44.001 TS: DVB-C Netzwerk/394MHz/RTL Television Transport error indicator (total 1)
2020-03-04 16:55:50.247 http: 127.0.0.1: HTTP/1.1 HEAD /imagecache/134 -- 404
2020-03-04 16:55:50.253 http: 127.0.0.1: HTTP/1.1 HEAD /imagecache/51 -- 404
2020-03-04 16:55:50.558 http: 127.0.0.1: HTTP/1.1 HEAD /imagecache/48 -- 404
2020-03-04 16:55:51.468 subscription: 0009: "127.0.0.1 [  | Kodi Media Center ]" unsubscribing from "RTL Television", hostname="127.0.0.1", username="127.0.0.1", client="Kodi Media Center"
2020-03-04 16:55:51.474 mpegts: 218MHz in DVB-C Netzwerk - tuning on Silicon Labs Si2168 #0 : DVB-C #0
2020-03-04 16:55:51.474 subscription: 000B: "127.0.0.1 [  | Kodi Media Center ]" subscribing on channel "ZDFinfo HD", weight: 150, adapter: "Silicon Labs Si2168 #0 : DVB-C #0", network: "DVB-C Netzwerk", mux: "218MHz", provider: "ZDFvision", service: "ZDFinfo HD", profile="htsp", hostname="127.0.0.1", username="127.0.0.1", client="Kodi Media Center"
2020-03-04 16:55:51.756 tbl-eit: eit: 218MHz in DVB-C Netzwerk: invalid checksum (len 3489, errors 1)
2020-03-04 16:55:51.857 tbl-base: nit: 218MHz in DVB-C Netzwerk: invalid checksum (len 791, errors 1)
2020-03-04 16:55:51.946 mpegts: mux 458MHz in DVB-C Netzwerk old params DVB-C freq 458000000 sym 6900000 mod QAM/256 fec NONE ds 0 plp -1 (00020000)
2020-03-04 16:55:51.946 mpegts: mux 458MHz in DVB-C Netzwerk new params DVB-C freq 458000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020000)
2020-03-04 16:55:52.154 TS: DVB-C Netzwerk/218MHz/ZDFinfo HD: H264 @ #563: Invalid start code 6c:3e:87
2020-03-04 16:55:52.187 tbl-base: sdt: 218MHz in DVB-C Netzwerk: invalid checksum (len 773, errors 1)
2020-03-04 16:55:52.205 TS: DVB-C Netzwerk/218MHz/ZDFinfo HD Transport error indicator (total 1)
2020-03-04 16:55:52.279 mpegts: mux 394MHz in DVB-C Netzwerk old params DVB-C freq 394000000 sym 6900000 mod QAM/64 fec NONE ds 0 plp -1 (00020040)
2020-03-04 16:55:52.279 mpegts: mux 394MHz in DVB-C Netzwerk new params DVB-C freq 394000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020040)
2020-03-04 16:55:52.279 mpegts: mux 370MHz in DVB-C Netzwerk old params DVB-C freq 370000000 sym 6900000 mod QAM/64 fec NONE ds 0 plp -1 (00020040)
2020-03-04 16:55:52.279 mpegts: mux 370MHz in DVB-C Netzwerk new params DVB-C freq 370000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020040)
2020-03-04 16:55:52.279 mpegts: mux 362MHz in DVB-C Netzwerk old params DVB-C freq 362000000 sym 6900000 mod QAM/64 fec NONE ds 0 plp -1 (00020040)
2020-03-04 16:55:52.279 mpegts: mux 362MHz in DVB-C Netzwerk new params DVB-C freq 362000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020040)
2020-03-04 16:55:52.479 TS: DVB-C Netzwerk/218MHz/ZDFinfo HD: H264 @ #563 Continuity counter error (total 1)
2020-03-04 16:55:52.499 TS: DVB-C Netzwerk/218MHz/ZDFinfo HD: MPEG2AUDIO @ #656 Continuity counter error (total 1)
2020-03-04 16:55:52.499 TS: DVB-C Netzwerk/218MHz/ZDFinfo HD: AC3 @ #566 Continuity counter error (total 1)
2020-03-04 16:55:52.543 TS: DVB-C Netzwerk/218MHz/ZDFinfo HD: DVBSUB @ #1671 Continuity counter error (total 1)
2020-03-04 16:55:52.658 TS: DVB-C Netzwerk/218MHz/ZDFinfo HD: MPEG2AUDIO @ #567 Continuity counter error (total 1)
2020-03-04 16:55:52.700 TS: DVB-C Netzwerk/218MHz/ZDFinfo HD: MPEG2AUDIO @ #564 Continuity counter error (total 1)
2020-03-04 16:55:52.821 TS: DVB-C Netzwerk/218MHz/ZDFinfo HD: TELETEXT @ #568 Continuity counter error (total 1)
2020-03-04 16:55:53.182 mpegts: mux 402MHz in DVB-C Netzwerk old params DVB-C freq 402000000 sym 6900000 mod QAM/256 fec NONE ds 0 plp -1 (00020000)
2020-03-04 16:55:53.182 mpegts: mux 402MHz in DVB-C Netzwerk new params DVB-C freq 402000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020000)
2020-03-04 16:55:53.182 mpegts: mux 410MHz in DVB-C Netzwerk old params DVB-C freq 410000000 sym 6900000 mod QAM/256 fec NONE ds 0 plp -1 (00020000)
2020-03-04 16:55:53.182 mpegts: mux 410MHz in DVB-C Netzwerk new params DVB-C freq 410000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020000)
2020-03-04 16:55:53.182 mpegts: mux 418MHz in DVB-C Netzwerk old params DVB-C freq 418000000 sym 6900000 mod QAM/256 fec NONE ds 0 plp -1 (00020000)
2020-03-04 16:55:53.182 mpegts: mux 418MHz in DVB-C Netzwerk new params DVB-C freq 418000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020000)
2020-03-04 16:55:53.183 mpegts: mux 426MHz in DVB-C Netzwerk old params DVB-C freq 426000000 sym 6900000 mod QAM/256 fec NONE ds 0 plp -1 (00020000)
2020-03-04 16:55:53.183 mpegts: mux 426MHz in DVB-C Netzwerk new params DVB-C freq 426000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020000)
2020-03-04 16:55:53.183 mpegts: mux 434MHz in DVB-C Netzwerk old params DVB-C freq 434000000 sym 6900000 mod QAM/256 fec NONE ds 0 plp -1 (00020000)
2020-03-04 16:55:53.183 mpegts: mux 434MHz in DVB-C Netzwerk new params DVB-C freq 434000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020000)
2020-03-04 16:55:53.183 mpegts: mux 442MHz in DVB-C Netzwerk old params DVB-C freq 442000000 sym 6900000 mod QAM/256 fec NONE ds 0 plp -1 (00020000)
2020-03-04 16:55:53.183 mpegts: mux 442MHz in DVB-C Netzwerk new params DVB-C freq 442000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020000)
2020-03-04 16:55:53.183 mpegts: mux 450MHz in DVB-C Netzwerk old params DVB-C freq 450000000 sym 6900000 mod QAM/256 fec NONE ds 0 plp -1 (00020000)
2020-03-04 16:55:53.183 mpegts: mux 450MHz in DVB-C Netzwerk new params DVB-C freq 450000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020000)
2020-03-04 16:55:53.770 tbl-base: bat: 218MHz in DVB-C Netzwerk: invalid checksum (len 904, errors 1)
2020-03-04 16:55:54.473 mpegts: mux 346MHz in DVB-C Netzwerk old params DVB-C freq 346000000 sym 6900000 mod QAM/256 fec NONE ds 0 plp -1 (00020000)
2020-03-04 16:55:54.473 mpegts: mux 346MHz in DVB-C Netzwerk new params DVB-C freq 346000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020000)
2020-03-04 16:55:55.048 tbl-base: cat: 218MHz in DVB-C Netzwerk: invalid checksum (len 42, errors 1)
2020-03-04 16:55:55.491 mpegts: mux 378MHz in DVB-C Netzwerk old params DVB-C freq 378000000 sym 6900000 mod QAM/64 fec NONE ds 0 plp -1 (00020040)
2020-03-04 16:55:55.491 mpegts: mux 378MHz in DVB-C Netzwerk new params DVB-C freq 378000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020040)
2020-03-04 16:55:55.491 mpegts: mux 386MHz in DVB-C Netzwerk old params DVB-C freq 386000000 sym 6900000 mod QAM/64 fec NONE ds 0 plp -1 (00020040)
2020-03-04 16:55:55.491 mpegts: mux 386MHz in DVB-C Netzwerk new params DVB-C freq 386000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020040)
2020-03-04 16:55:55.491 mpegts: mux 354MHz in DVB-C Netzwerk old params DVB-C freq 354000000 sym 6900000 mod QAM/64 fec NONE ds 0 plp -1 (00020040)
2020-03-04 16:55:55.491 mpegts: mux 354MHz in DVB-C Netzwerk new params DVB-C freq 354000000 sym 6900000 mod QAM/256 fec 3/5 ds 0 plp -1 (00020040)
2020-03-04 16:55:57.296 tbl-base: pmt: 218MHz in DVB-C Netzwerk: invalid checksum (len 138, errors 1)
2020-03-04 16:56:01.752 tbl-eit: eit: 218MHz in DVB-C Netzwerk: invalid checksum (len 3668, errors 188)
2020-03-04 16:56:02.347 tbl-base: sdt: 218MHz in DVB-C Netzwerk: invalid checksum (len 652, errors 17)
2020-03-04 16:56:02.490 TS: DVB-C Netzwerk/218MHz/ZDFinfo HD: H264 @ #563 Continuity counter error (total 15506)
2020-03-04 16:56:02.491 tbl-base: nit: 218MHz in DVB-C Netzwerk: invalid checksum (len 791, errors 48)
2020-03-04 16:56:02.529 TS: DVB-C Netzwerk/218MHz/ZDFinfo HD: AC3 @ #566 Continuity counter error (total 268)
2020-03-04 16:56:02.568 TS: DVB-C Netzwerk/218MHz/ZDFinfo HD: DVBSUB @ #1671 Continuity counter error (total 3)
2020-03-04 16:56:02.603 TS: DVB-C Netzwerk/218MHz/ZDFinfo HD: MPEG2AUDIO @ #656 Continuity counter error (total 106)
2020-03-04 16:56:02.735 TS: DVB-C Netzwerk/218MHz/ZDFinfo HD: MPEG2AUDIO @ #564 Continuity counter error (total 173)
2020-03-04 16:56:02.781 TS: DVB-C Netzwerk/218MHz/ZDFinfo HD: MPEG2AUDIO @ #567 Continuity counter error (total 80)
2020-03-04 16:56:02.812 TS: DVB-C Netzwerk/218MHz/ZDFinfo HD: TELETEXT @ #568 Continuity counter error (total 146)
2020-03-04 16:56:03.508 TS: DVB-C Netzwerk/218MHz/ZDFinfo HD: H264 @ #563 Corrupted PES header (errors 4)
2020-03-04 16:56:04.319 TS: DVB-C Netzwerk/218MHz/ZDFinfo HD Transport error indicator (total 16)
2020-03-04 16:56:06.423 subscription: 000B: "127.0.0.1 [  | Kodi Media Center ]" unsubscribing from "ZDFinfo HD", hostname="127.0.0.1", username="127.0.0.1", client="Kodi Media Center"
Can you try the tvh server version you find in this repo?
https://addons.tnds82.xyz/.tnds82
I tried but this addon /repository does not work at all for me, instead produces this error after installation.
2020-03-05 07:41:42.893 T:3573117824   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                             - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
                                            Error Type: <type 'exceptions.NameError'>
                                            Error Contents: name 'jeos' is not defined
                                            Traceback (most recent call last):
                                              File "/storage/.kodi/addons/service.tnds82/default.py", line 25, in <module>
                                                if jeos[0] == 'LibreELEC Add-ons':
                                            NameError: name 'jeos' is not defined
                                            -->End of Python script error report<--
I’ll try later and see what’s the problem with that. The rest I’ll test over the weekend
Hi @Steasenburger, sorry I haven’t replied before but I could only get my mygica tuner today I’ll test it in the next few days. Do you still have problems with tvheadend? One workaround to try the repository I referred is to revert to stable, install the repository and tvh 4.3 and “reupdate” to nightly.
unfortunately I’m not at home till next week, so I can’t test it till then, but I would guess yes .
But reverting my S905x3 box to stable is not an option until there is a stable release for this soc.
But whenever a stable version of coreelec is released (the last one is quite a while ago) I will try it out.
Yes, you’re right, sorry, I forgot which box your was. When you come back please inform us of the state of things.
I’m back at home, but the situation hasn’t really changed.
Now often the playback won’t start at all, until I fully restart the system.
Here I have once again the logs for you :
http://ix.io/2eow
This was solved using the tvh build found on this topic:
Yes this version did the trick, if anyone else is experiencing this issue
I think TVH Backend deserves some love, if anyone interested, here is tvheadend42 package.mk and patches, which is working fine (at least for me), based on fairly recent commit (using it couple of weeks, months?):
tvheadend42.zip (10.1 kB)
Some people use tvh 4.2 others 4.3, what best suites them. Yours is 4.2, right? The other is 4.3.
nope, 43, i just didnt renamed the package… I used 42 without problems, then switch to 43 and again without problems.
I know, that 4.3 solves some problems for some people, but for some reason, official stable for Leia is still 4.2 (and I believe quite old). I dont know those reasons, therefore I didnt polish package to tvheadend43 or create Pull Request.
But considering number of complains here on forum, and considering I am building only ng-nightly for S905X3 and legacy for C2, I feeling this could help other to create his own package without any hassle for any device they own. And maybe as silent question to developers, if they wouldnt want to bump although LE is still on 42 :slight_smile:
Happy to accept a PR for 4.3 if you want to send one.
I only read the release notes and it mentioned 4.2, I didn’t have the time to test it. But the last commit upgrades to 4.3 but doesn’t mention it. Thanks.
Allright, I could look on this later. At least more people could test it and see if its OK or not I guess.
Edit: https://github.com/CoreELEC/CoreELEC/pull/235
Could you look @235? :slight_smile:
