roden
21 November 2025 21:53
1
Hey all, i Have a HW-QC600 Soundbar, what should i have my channel output settings set to?
I have passthrough enabled, using eARC but the channel setting seems to change the sound and im not sure what it should be set at?
Currently set to 3.1ch that i think is correct, running on an N2 latest version.
Thanks.
roden
7 December 2025 17:59
2
Anyone? Cant believe nobody knows?
nissel
17 December 2025 22:39
3
3.1 should be fine, but you could try downloading these multi channel samples at GitHub - sfiera/flac-test-files: FLAC test files for multi-channel sound systems and try different settings with the 5.1 and 7.1 samples and see what works / what you prefer.
It’s probably more important to turn on Passthrough and enable all the codecs your soundbar/eArc support (probably most)
roden
22 December 2025 18:10
4
Heya thanks, i currently have passthrough enabled, and just set it to max 7.1, it seems to sound alot better, at 3.1 it sounds weird and dull, assume the soundbar will do what it needs to?
nissel
22 December 2025 18:40
5
Yeah I would assume the sound bar would do phantom rear channels etc and down mix from 7.1 appropriately.
roden
25 December 2025 10:23
6
Brilliant thanks, ill lease it like that
system
Closed
26 March 2026 16:23
7
