I have problems to install spanish laguange, it looks that the repository is not updated, this is the log:
2025-06-28 02:23:26.628 T:4027 info <general>: Loading skin file: DialogSelect.xml, load type: KEEP_IN_MEMORY
2025-06-28 02:23:37.956 T:4027 info <general>: Loading skin file: DialogConfirm.xml, load type: KEEP_IN_MEMORY
2025-06-28 02:23:39.502 T:4027 error <general>: CCurlFile::Open - <https://addons.coreelec.org/omega/resource.language.es_es/resource.language.es_es-11.0.88.zip.sha256> Failed with code 404:
2025-06-28 02:23:39.502 T:4027 error <general>: Failed to find hash for https://addons.coreelec.org/omega/resource.language.es_es/resource.language.es_es-11.0.88.zip from HTTP header and in separate file
2025-06-28 02:23:39.502 T:4027 error <general>: CAddonInstallJob[resource.language.es_es]: failed to resolve addon install source path
2025-06-28 02:23:39.505 T:4027 info <general>: Loading skin file: DialogConfirm.xml, load type: KEEP_IN_MEMORY
How could I fix it?
Best regards.
