Speed Tester (kodi)
I have found the SpeedTester in Kodi repo does not work with CE.
Kodi repo version is 1.1.2 + Matrix
The same author has released a 1.1.3 + Matrix version that works ok in CE.
I found it last year in their github and posted up in the Kodi forum’s but only got replies from other users that had same issue.
I tried the kodi repo version again this week but it just hangs .
I have now reinstalled the 1.1.3 version and it works good.
script.speedtester-1.1.3+matrix.1.zip (1.5 MB)
Note this addons max speed is limited to the max download from what ever external provider it finds at the time of test but is a good test if you want to check your box can do more than 100Mbit. etc.
I used it to find a fault ethernet cable in my house that limited streaming from one of my switches.
