Strange video effects
Hi all
If you can download and see this movie (sorry I dont know how to share it better than that) [link removed] or short video here [link removed]. you will see many artifact lag and strange cuted image video immediately after the presentation … (CoreELEC 9.2.5 AmLogic S912) but if I play this movie with my android sony TV all work fine …
Whats wrong ?
With CE I do not use any whitelist and the box upscale perfectly all movies included this one but with strange cuted image and artefact lag…
Thanks !
SHORT video issue sample [link removed]
LONG video issue sample (original for checking data) [link removed]
Hey linuxo
I get the same garbage with this movie so don’t worry may be CE bug …??? Are you sure that’s work fine with your android tv ?
Yes 100% sure … my android TV play this movie perfectly
You lucky if your android tv play this file… CE do not
I removed the long video links as we are here not a illegal video share center.
Also please upload your samples to another hoster. Like me I am not able to download anything, it just forward me to advertisement web pages.
EDIT:
I removed all links as also Kaspersky popped up on your links.
Maybe you just change your (illegal) download source and the issue will be fixed by itself…
Yes sure… understood… but illegal or not CE do not play this file correctly whereas Android TV do … this is the point
You can upload only a snipped from the file, less than 10s. And please use another, virus free hoster.
Or you first try another hoster if the files plays without any issue. Then your hoster did something wrong with the encoding.
BTW: S912 will be abandoned soon as it’s only supported by Amlogic project. There is no active development since months on Amlogic project. 3.14 kernel is end of live.
Well the problem with a snipped from a file is that I have to cut it and ffmpeg fix the issue when it do it… the only way to see the trouble its to see the full file… In other hand when I post the file on big files server like uptobox, 1fichier etc they server put some announcement so you just have to close the windows and retry there is no any virus or any bad things there… about piracy its not but I can rename the file
About the S912 its a very bad new if it will be abandoned because its the BEST SoC actually regarding the price … instead to pay for Nvidia I prefer to buy my Sony Android TV with MT5893 / Mali G-52 GPU whereas its a best ever SoC regarding the Sony service and Updates …
Then please contact your uploader he should proper encode the files when ripping off somewhere!
Case closed!
S912 was a “hack” in 3.14 and it will be not supported in newer kernels. We tried and it’s not possible wihtout a hugh manpower. There was never a needed mali blob released for S912.
You are still able to use it in future. If you want to go with Kodi Matrix you may think about a hardware upgrade…
Upgrade with any 905xxx Amlogic SoC ? or which one ?
BTW if you want to check why this file do not work with CE I put it in MY LEGAL storage as LEGAL owner you can download it for free to check what is the garbage data which play in my android Tv and not in CE https://1fichier.com/?0rlhlv0935die4k1a6p2 (close the subscribe windows and download the file)
I do not find any SM1 or G12 AMLogic Android box … Please can you tell me specifically which one I have to looking for ?
Here:
SM1 = S905X3, G12A = S905X2, G12B = S922X.
Ah… ok… understood… Big Thanks !
The last but not the least is it possible to make a CE backup through backup CE option in my S912 Device and restore it to the S905X3 device in same CE option (ng) or not ? I mean is it possible to import my full profile including add-ons from my 9.2.5 CE S912 device to my S905X3 9.2.5 CE ng device ?
It should work OK, but there are no guarantees when switching from 3.14 to 4.9 kernel.
Yes my S912 have 3.xx kernel where the S905X3 have the last 4.xx kernel … I will try and left the result here when done
I can see the release note of the new kernel and frankly concretely I do not see exactly what this new 4.19 kernel brings to android tv boxes …
There’s a plethora of under-the-hood improvements and fixes the CE team has done to the Amlogic kernel sources. In addition, the modules which are used for decoding different video formats were updated by Amlogic, and fixed or improved in some situations by our team. There are video formats and/or files which do not work properly on the 3.14 kernel, such as newer HEVC encodes.
The 3.14 kernel does not support HLG nor HDR10+ formats.
It obviously does not support the newer SoCs, like S905X2, S905X3 and S922X.
CoreELEC 19, which uses Kodi Matrix will only use the 4.9 kernel, so you will not be able to update your S912 to Matrix.
