Hi!
using latest stable coreelec 21.0 ne with my Box s905x4
my setup is Sony 4k tv connected to AVR (YAMAHA RX-V673) with HDMI-ARC
and the BOX S905X4 connected with Ugreen cable to HDMI4 (Directed to Sony)
configure pass-through for DD and DTS
I am getting Stutter and lost signal in the AVR (every 4-5 minutes) with DTS.
tested few video with DTS audio
for DD I not getting this issues.
dmesg
https://paste.coreelec.org/LoonyJohnnie
kodi.log
https://paste.coreelec.org/WormholeHaste
this lost signal/jump ( I don’t know how to describe it) append at 09:48:50
also got experience of starting video that not played smooth , and I jump 10 second back to fix it.
Thank you .
just tried …
21.1-Omega_nightly_20240604
didn’t help
upload logs from this build?
As there is no known issue with CE you better try other combination of connections.
AVR are well known to produce strange errors.
Better use the ARC port of the TV and use passthrough.
to verify it is related to CE , I try to play the same video with kodi that install on Android TV
and it worked.
what do you mean?
connect the ARC port to the BOX?
No, it’s because CE use better audio quality then Android. Disable passthrough or use ARC port of TV!
Or also try other HDMI cables with better quality.
I still not sure what it mean use ARC
HDMI ARC port connected to AVR (HDMI3)
CE connected to HDMI4 (NOT ARC PORT)
ports
Zuma
10 June 2024 03:01
8
CE connected to AVR & AVR connected to ARC TV port ?
Hi
CE Connected to the Sony TV hdmi4
AVR Conncted to Sony TV hdmi 3 (ARC)
I can’t connect the CE directly to the AVR, no 4K Support.
You dont need to connect CoreELEC to avr
In CoreELEC settings disable pass-through
Let your TV now return audio to avr through arc port like you have it wired
If I disable the pass-through and set the Number of channels to 4.1 in Kodi(as my speaker setup)
I am getting signal of Dolby Digital in my AVR, but the Video is DTS…
it should be settings in Sony TV?
Yes
If you are using HDMI ARC out to receiver/ soundbar
The TV determines which is passthrough/audio return
Possible Sony cant pass DTS audio out.
Also check TV settings, can you change from Bitstream to PCM?
Or vice versa see if there us different
here report of the same issue that I am facing with CE
It should be related to Sony.
opened 05:53PM - 27 Jan 22 UTC
Triage: Needed
## Bug report
### Describe the bug
Here is a clear and concise description of … what the problem is:
I am running Kodi on an Android TV ([65X950G](https://www.sony.com/electronics/support/televisions-projectors-lcd-tvs-android-/xbr-65x950g/specifications)). I have the TV connected to an [ONKYO HT-RC230 AVR](https://www.manualslib.com/manual/115399/Onkyo-29400468.html#manual) via HDMI ARC, which should be capable of decoding Dolby Digital and DTS audio. I have enabled audio passthrough on the TV, and in the [Kodi audio settings](https://i.imgur.com/dr3NsVV.png).
I am attempting to play a [demo video file](https://thedigitaltheater.wetransfer.com/downloads/24c2cb03a84ef8aefdf9bfe962dcdf6120161120155634/6ce5fa) which contains DTS 5.1 audio. During playback the video plays normally, but the audio cuts in and out for half a second for the entire length of the clip. My AVR is displaying DTS and the audio is playing through my speakers, the only issue is the drop outs. I have streamed the video over SMB and played it locally using a USB stick with the same issue.
Playing a [Dolby Digital video file
](https://thedigitaltheater.wetransfer.com/downloads/7e977e3673afe44613ea0e4bec6f824620160427225530/d39a07) with passthrough enabled works perfectly with no audio drop outs. Enabling Dolby Digital transcoding works as well. The issue is only with DTS passthrough.
I have played the same DTS file using the built in Sony media player and that works fine as well.
## Expected Behavior
Here is a clear and concise description of what was expected to happen:
Audio should play normally with no drop outs when DTS passthrough is enabled.
## Actual Behavior
The audio drops in and out when DTS passthrough is enabled with a DTS capable AVR.
## Possible Fix
Not a fix, but the logs are showing warnings like
ActiveAE - large audio sync error: -1207.191499
which may be relevant
### To Reproduce
Steps to reproduce the behavior:
1. Download a video file with a DTS audio stream https://thedigitaltheater.wetransfer.com/downloads/24c2cb03a84ef8aefdf9bfe962dcdf6120161120155634/6ce5fa
2. Enable Audio passthrough with DTS capable receiver enabled https://i.imgur.com/dr3NsVV.png
3. Play the video play using Kodi on an Android TV (Possibly just an X950G issue)
### Debuglog
The debuglog can be found here:
https://pastebin.pl/view/raw/1e4613f8
### Screenshots
Here are some links or screenshots to help explain the problem:
Video with DTS stream: https://thedigitaltheater.wetransfer.com/downloads/24c2cb03a84ef8aefdf9bfe962dcdf6120161120155634/6ce5fa
Audio Passsthrough settings: https://i.imgur.com/dr3NsVV.png
## Additional context or screenshots (if appropriate)
Here is some additional context or explanation that might help:
### Your Environment
Used Operating system:
- [x] Android
- [ ] iOS
- [ ] tvOS
- [ ] Linux
- [ ] OSX
- [ ] Windows
- [ ] Windows UWP
- Operating system version/name:
Sony BRAVIA 4K UR2 with Android 9.0.0 API level 28, kernel: Linux ARM 32-bit version 4.9.125
2022-01-27 11:48:51.743 T:20328 INFO <general>: Device 1
2022-01-27 11:48:51.743 T:20328 INFO <general>: m_deviceName : AudioTrack (RAW)
2022-01-27 11:48:51.744 T:20328 INFO <general>: m_displayName : AudioTrack (RAW)
2022-01-27 11:48:51.744 T:20328 INFO <general>: m_displayNameExtra: Android IEC packer
2022-01-27 11:48:51.744 T:20328 INFO <general>: m_deviceType : AE_DEVTYPE_HDMI
2022-01-27 11:48:51.744 T:20328 INFO <general>: m_channels : FL, FR, FC, LFE, SL, SR, BL, BR, BC, BLOC, BROC
2022-01-27 11:48:51.744 T:20328 INFO <general>: m_sampleRates : 32000,44100,48000,88200,96000,176400,192000,32000,44100,48000,88200,96000,176400,192000
2022-01-27 11:48:51.744 T:20328 INFO <general>: m_dataFormats : AE_FMT_S16LE,AE_FMT_FLOAT,AE_FMT_RAW,AE_FMT_S16LE,AE_FMT_FLOAT,AE_FMT_RAW
2022-01-27 11:48:51.744 T:20328 INFO <general>: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512,STREAM_TYPE_DTSHD,STREAM_TYPE_DTSHD_MA
- Kodi version: [kodi-20220122-62b06097-Matrix-armeabi-v7a.apk](https://mirrors.kodi.tv/nightlies/android/arm/Matrix/kodi-20220122-62b06097-Matrix-armeabi-v7a.apk)
*note: Once the issue is made we require you to update it with new information or Kodi versions should that be required.
Team Kodi will consider your problem report however, we will not make any promises the problem will be solved.*
from my tests , Kodi on AndroidTV work fine with DTS
A quick read of bug report
Indicates user had passthrough enabled in Kodi
And Sony TV
I thought you disabled passthrough in Kodi/CoreELEC.
So TV only was processing audio return HDMI arc.
Also there can be many issues with different system audio configs and AVR
didn’t disabled pass-though, the TV not process DTS (the AVR not getting DTS signal for DTS Video File)
I able to isolate the problem.
connect my second box - S905X2 (gxl_p212_2g)
using the same cable with SonyTV and My AVR
with the same video file
and DTS worked smooth.
so the issue is with S905X4 Vontar, that was not the best box from the beginning.
