on previos version i can play UHD video with very high bitrate trough network.
With last version, kodi goes stuttering with a normal bitrate (35v+5a Mb/s).
Adapter works like a gigabit adapter:
ethtool usbnet0
Settings for usbnet0:
Supported ports: [ TP MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Half 1000baseT/Full
Supported pause frame use: No
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Advertised pause frame use: Symmetric
Advertised auto-negotiation: Yes
Advertised FEC modes: Not reported
Link partner advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Link partner advertised pause frame use: No
Link partner advertised auto-negotiation: Yes
Link partner advertised FEC modes: Not reported
Speed: 1000Mb/s
Duplex: Full
Port: MII
PHYAD: 3
Transceiver: internal
Auto-negotiation: on
Supports Wake-on: pg
Wake-on: g
Current message level: 0x00000007 (7)
drv probe link
Link detected: yes
I’m using advancedsettings.xml (as usual)
1
1258291200
40
I can see the movie only with initial pause, buffer goes to 100%, then while playing it stay about 50% (+/- 10%).
Why this problem?
Thanks in advance
ps: 905X + 2gb ram + usb3 (but with usb2 port) gigabit adapter
