Subtitle sync with live tv
I am using Kodi (21.0-Omega (20.90.910) - Running on Amlogic S905D rev d
my problem is when I try to use subtitles with live TV movies I load subtitles from my storage and subtitle begins but no sync if the movie begins from 20 minutes the subtitle start from the first line. i also limited in subtitle offset so I cannot adjust the subtitle with the movie
as I am new user I can not attach log file so I copy part of it here
2024-07-13 09:48:49.594 T:6636     info <general>: Loading skin file: Home.xml, load type: KEEP_IN_MEMORY
2024-07-13 09:48:49.788 T:6636  warning <general>: Skin has invalid include: skinshortcuts-template-widget1
2024-07-13 09:48:49.788 T:6636  warning <general>: Skin has invalid include: skinshortcuts-template-widget2
2024-07-13 09:48:49.789 T:6636    error <general>: unmatched parentheses in string.isempty(skin.string(widget.trans)
2024-07-13 09:48:49.929 T:6636    error <general>: Control has invalid animation type (no condition or no type)
2024-07-13 09:48:50.044 T:6835  warning <general>: OutputPicture - timeout waiting for buffer
2024-07-13 09:48:50.831 T:6656     info <general>: Skipped 6 duplicate messages..
2024-07-13 09:48:50.831 T:6656    error <general>: Sink Timer expired for more than buffer time: 0.15s
2024-07-13 09:48:57.953 T:6636     info <general>: Loading skin file: Settings.xml, load type: KEEP_IN_MEMORY
2024-07-13 09:48:59.852 T:6636     info <general>: Loading skin file: SettingsCategory.xml, load type: KEEP_IN_MEMORY
2024-07-13 09:49:37.356 T:6713  warning <general>: UpdateTimerTypes: Not calling add-on 'pvr.iptvsimple'. Add-on not (yet) connected.
2024-07-13 09:49:37.369 T:6713  warning <general>: GetTimers: Not calling add-on 'pvr.iptvsimple'. Add-on not (yet) connected.
2024-07-13 09:50:00.047 T:6636     info <general>: Loading skin file: FileBrowser.xml, load type: KEEP_IN_MEMORY
2024-07-13 09:50:34.855 T:6636     info <general>: [WHITELIST] Searching the whitelist for: width: 1920, height: 1080, fps: 50.000, 3D: false
2024-07-13 09:50:34.855 T:6636     info <general>: Display resolution ADJUST : 3840x2160 @ 50.00 - Full Screen (16) (weight: 0.000)
2024-07-13 09:50:34.871 T:6636     info <general>: GLES: Maximum texture width: 4096
2024-07-13 09:52:03.080 T:6636     info <general>: Loading skin file: FileBrowser.xml, load type: KEEP_IN_MEMORY
2024-07-13 09:52:08.207 T:6804     info <general>: Closing stream player 3
2024-07-13 09:52:08.207 T:6804     info <general>: Opening stream: 0 source: 1025
2024-07-13 09:52:08.212 T:6804     info <general>: CDVDSubtitlesLibass: Using libass version 1701000
2024-07-13 09:52:08.212 T:6804     info <general>: CDVDSubtitlesLibass: Creating ASS library structure
2024-07-13 09:52:08.212 T:6804     info <general>: CDVDSubtitlesLibass: Initializing ASS Renderer
2024-07-13 09:52:08.218 T:6804     info <general>: CDVDSubtitlesLibass: Initializing ASS library font settings
2024-07-13 09:52:08.315 T:6804     info <general>: CDVDSubtitlesLibass: Creating new ASS track
2024-07-13 09:53:31.455 T:6835  warning <general>: OutputPicture - timeout waiting for buffer
2024-07-13 09:54:37.984 T:6713     info <general>: Skipped 1 duplicate messages..
2024-07-13 09:54:37.984 T:6713  warning <general>: UpdateTimerTypes: Not calling add-on 'pvr.iptvsimple'. Add-on not (yet) connected.
2024-07-13 09:54:37.997 T:6713  warning <general>: GetTimers: Not calling add-on 'pvr.iptvsimple'. Add-on not (yet) connected.
2024-07-13 09:57:18.252 T:6636     info <general>: Loading skin file: AddonBrowser.xml, load type: KEEP_IN_MEMORY
2024-07-13 09:57:18.280 T:6636  warning <general>: Skin has invalid include:
2024-07-13 09:57:18.692 T:6835  warning <general>: OutputPicture - timeout waiting for buffer
2024-07-13 09:57:20.976 T:10446    info <general>: Skipped 10 duplicate messages..
2024-07-13 09:57:20.976 T:10446   error <general>: CCurlFile::Open - <https://addons.coreelec.org/Amlogic-ng/21.0/arm/pvr.sledovanitv.cz/resources/logo.png> Failed with code 404:
2024-07-13 09:57:24.014 T:10445   error <general>: DoWork - Direct texture file loading failed for special://masterprofile/Thumbnails/f/f1eb749d.jpg
2024-07-13 09:57:26.595 T:10446   error <general>: CCurlFile::Open - <https://addons.coreelec.org/Amlogic-ng/21.0/arm/pvr.sledovanitv.cz/resources/logo.png> Failed with code 404:
2024-07-13 09:57:31.824 T:6636     info <general>: Loading skin file: DialogAddonInfo.xml, load type: KEEP_IN_MEMORY
2024-07-13 09:57:34.830 T:6636     info <general>: Loading skin file: DialogAddonSettings.xml, load type: KEEP_IN_MEMORY
2024-07-13 09:57:51.310 T:6835  warning <general>: OutputPicture - timeout waiting for buffer
2024-07-13 09:58:32.100 T:6636     info <general>: Skipped 1 duplicate messages..
2024-07-13 09:58:32.100 T:6636     info <general>: AddOnLog: pvr.iptvsimple: pvr.iptvsimple - SetSetting - Changed Setting 'timeshiftEnabled' from 0 to 1
2024-07-13 09:58:32.101 T:6636    error <general>: Unknown setting type of 'ffmpegdirectSettings' for IPTV Simple Client
2024-07-13 09:58:51.629 T:6835  warning <general>: OutputPicture - timeout waiting for buffer
2024-07-13 09:59:01.838 T:6636     info <general>: AddOnLog: pvr.iptvsimple: pvr.iptvsimple - SetSetting - Changed Setting 'timeshiftEnabledCustom' from 0 to 1
2024-07-13 09:59:01.838 T:6636    error <general>: Unknown setting type of 'ffmpegdirectSettings' for IPTV Simple Client
2024-07-13 09:59:27.758 T:6636    error <general>: Unknown setting type of 'ffmpegdirectSettings' for IPTV Simple Client
2024-07-13 09:59:38.456 T:6713  warning <general>: UpdateTimerTypes: Not calling add-on 'pvr.iptvsimple'. Add-on not (yet) connected.
2024-07-13 09:59:38.472 T:6713  warning <general>: GetTimers: Not calling add-on 'pvr.iptvsimple'. Add-on not (yet) connected.
2024-07-13 10:00:46.579 T:6636    error <general>: Unknown setting type of 'ffmpegdirectSettings' for IPTV Simple Client
2024-07-13 10:00:53.249 T:6636     info <general>: Loading skin file: DialogConfirm.xml, load type: KEEP_IN_MEMORY
2024-07-13 10:00:58.730 T:6636     info <general>: Loading skin file: DialogSettings.xml, load type: LOAD_EVERY_TIME
2024-07-13 10:01:06.591 T:6636  warning <general>: GetChannelGroups: Not calling add-on 'pvr.iptvsimple'. Add-on not (yet) connected.
2024-07-13 10:01:06.614 T:6636  warning <general>: GetChannels: Not calling add-on 'pvr.iptvsimple'. Add-on not (yet) connected.
2024-07-13 10:01:06.799 T:6636  warning <general>: GetChannelGroups: Not calling add-on 'pvr.iptvsimple'. Add-on not (yet) connected.
2024-07-13 10:01:06.803 T:6636  warning <general>: GetChannels: Not calling add-on 'pvr.iptvsimple'. Add-on not (yet) connected.
2024-07-13 10:01:41.749 T:6835  warning <general>: OutputPicture - timeout waiting for buffer
