Thanks,my device is am8pro,
and coreelec version is ( CoreELEC-Amlogic-ne.aarch64-21.1-Omega_nightly_20240804-Generic.img.gz)。
When i play 24 frame film,the output signal is correct 24 frame,but but when i played 25 frame or 60 frame,the out put is double frame, 50hz and120 hz。i hope this can be improve,when i play 25 or 60 frame vidio,the output frame iscorrect,not double。
50Hz and 25Hz are both fine for 25fps. The problem is when the refresh rate isn’t evenly divisible by the frame-rate.
