Good afternoon,
I’ve been poking around the forums but I didn’t see this exact question.
I’ve had an N2 for a while now, and i recently picked up a couple of N2+'s for some projects. The older N2 is running a CoreElec install in my living room. I was curious if I can just swap in the SD card from the older N2 into the + without rebuilding?
I didn’t see separate listings in the device tree aside from 2G and 4G, so I’m guessing so long as both models are 4G I should be able to swap the SD card in and CoreElec will boot right up?
Void4ever
