I am failing to mount cifs using this command:
systemctl enable storage-movies.mount
Why CE fails to mount CIFS?
Thank you,
Thank you,
I have a cifs mount setup on all of my boxes, and it works fine.
It’s likely you have something configured incorrectly in your .mount file.
Can you please send a copy of your .mount file (remove any identifying data)?
Here are my confirgs
File name: storage-music.mount
File directory: ~/.config/system.d
.mount config (without the # comments):
[Unit]
Description=test cifs mount script
Requires=network-online.service
After=network-online.service
Before=kodi.service
[Mount]
What=//192.168.100.66/Music
Where=/storage/music
Options=username=MyName,password=MyPassword
Type=cifs
[Install]
WantedBy=multi-user.target
The file name storage-music.mount matches to the path at /storage/music
I can mount manually using the following command:
mount -t cifs -o username=MyName,password=MyPassowrd,vers=2.1 //192.168.100.66/Music /storage/music
Thanks,
Mine is very similar, so maybe it’s just a SMB version issue with your ‘server’.
Why don’t you try adding ,vers=2.1
to the Options
parameter and see if that works.
I did add, and is doesn’t work. I had to run a script on startup to mount using the command line.
