Tencent Aurora 4 pro box currently uses the latest coreelec ne 21 nightly version. I modified the dtb file and found a dtb file and copied it to the root directory of the USB disk. It works normally
After research by my netizens and I, we have solved the problem of dtb gigabit wired and wifi including bluetooth. In addition, we have also solved the prompt that the kernel version of dv is too low. I hope the official @Portisch can test the dtb file I modified. I am It is modified based on ugoos’ dtb. I will post the log later this evening. Please take care of it when you have time. Thank you.
First step would be check if two HEVC video streams are getting decoded.
The AML Decoder from what I see pulls out the EL from the NAL and sends to a 2nd decoder, so should see two - one for the BL and one for the EL if enable debug logging etc.
If that is happening, then need to check the Composer element - but that is in the dovi.ko so maybe not much can be looked at.
My feedback is that I and my netizens have studied and modified the DTB file together. My goal is to solve the problem of not needing to replace the modified DTB file in the next update without affecting ugoos x4. I have sent out the relevant logs of the DTB file I have modified now. Could you please take a look when you have time? Thank you.
