I got a A95X plus board and change the S905Y2 to S905Y2-J.Android can boot,the CE-ng 21 also can boot with g12a_s905y2_4g.dtb.The problem is kodi UI can’t display properly.It sparks.
Here is the dsemg log.
https://paste.coreelec.org/EmergingTended
Tested in LE 12,UI work fine,no wifi and bt.
tivo stream 4k can boot ce with s905y2_2g.dtb.wifi&bt work properly,but the hardware decoder locked.
original Android 9 dts
single.dts (86.5 KB)
any one who is intrested in the device can take a look
Hey, have you been able to figure it out? I’m looking to get a second device for another room that can boot CE-NG and have FEL support. I can get this Tivo Stream 4K which is available to ship for me.
failed,the hardware decoder can’t work.
update:
Recently, someone told me that based on the A95X PLUS motherboard, after replacing the chip with S905Y2 - J, it can achieve dual - layer Dolby Vision. I will update further if there is more news.
confirmed .s905y2-j can playback fel.
@YadaYada
