The abrupt re-handshake during playback caused a colour cast in Dolby Vision
I’ve been having similar issues as well. The device is AM8 Pro, this problem occurs on NE, not on NO. Another problem is that during the playback, the handshake will occasionally be re-shaken, that is, it will go black and then return to normal. However, if it’s a Dolby Vision movie, there will be a colour cast. This problem exists in both ne and no. Kodi under Android is normal.
NE is EOL, use NO.
