Would love to see this option on Coreelec.
Anyone seen this?
Anyone seen this?
Thanks this is something else. This allows you to play Tidal music from within Kodi with a slimmed down UI.
Tidal Connect is similar to Spotify Connect, it allows music to be sent to any device on your network from the Tidal app that is Tidal Connect capable. Similar to chromecast I suppose. Basically turns the phone into the remote, this would work with no UI interaction via Kodi.
