I’m kinda new to Coreelec and Odroid and cannot get the Archer T2U Nano AC600 (Bus 001 Device 009: ID 2357:011e TP-Link) to run with Coreelec. As far as I understand, this device should use the RTL8812AU driver, which should be supported with coreelec. However, the device is not recognized at all. I tried with 9.2.0 and the latest nightly from 20191107.
Here are the lusb and dmesg pastes from the latest nightly.
I don’t really understand why it isn’t working, I’ve been through countless threads but did not find a solution to this issue. Also not the most experienced guy with linux in general.
If it works I will push the changes to the CoreELEC repository. If not I will get an Archer T2U Nano AC600 to test with and see if I can figure out a solution.
