Transfer speed to attached storage device too slow
Hi everyone,
I have CoreELEC 21.2 running on a LePotato. Before that, I used to have an older version installed on an Odroid C2, which worked really well.
The problem is that I get very slow speeds when I try transferring files from my Windows PC to an external drive attached to LePotato using Samba.
I have no idea why. The Odroid C2 setup used to have good transfer speeds.
Do you have any idea why this is happening? Is there a workaround? I’d really appreciate some help here.
Thank you!
https://wiki.coreelec.org/coreelec:network
Hi! Thanks for the reply. I tried everything, and it’s still super slow.
Is there anything else I can try?
