Tutorial: Scheduled tasks in CoreELEC
You need to save file as UNIX formatted. But in your case it seems it was unicode with some strange characters in. Like 0x9c and 0x9d.
Thanks. I don’t know exactly the cause, but now we have a solution.
Kind regards
I followed the thread just to create a simple task scheduler for restarting a Docker container on every 6 hours, but the ‘‘docker’’ command has not been found in crontab.
My sh script is so simple:
#!/bin/sh
docker restart container
This is the entry in crontab:
30 */6 * * * sh /storage/.config/scripts/container-restart.sh
This is the error :
CoreELEC crond[4594]: USER root pid 5492 cmd sh /storage/.config/scripts/container-restart.sh
CoreELEC crond[4594]: /storage/.config/scripts/container-restart.sh: line 3: docker: not found
Could please help me to resolve this issue.Thanks in advance
In file container-restart.sh add this on top before your commands
source /etc/profile
or use full path to the binaries.
Wooool
What a quick and helpful reply. It’s works wright now :grinning: Thank you so much Sir. You saved my day.
By the way…I tried with the path but without any success.
I inserted this one:
PATH=/storage/.kodi/userdata/addon_data/service.system.docker/docker
Maybe
export PATH=$PATH:/storage/.kodi/addons/service.system.docker/bin
