Hi.
I would really appreciate if you can help me with my problem.
Install the latest version of coreelec to date on a tv box (X3 mini 4gb ram and 32gb storage, bluetooth, dual wifi, amlogic s905x3 processor).
I boot it through a 16gb micro sd, the problem is that it does not recognize neither the bluetooth, nor the wifi.
I am new to this but if you explain it to me I can understand.
I hope your support, thanks.
According to board photos over at Freaktab, the AP6255 is used.
Which DTB are you using?
I am using this sm1_s905x3_2g, however I don’t know how to apply the drivers for the AP6255 chip.
You can check what chip you have by running
ssh
udevadm info /sys/bus/sdio/devices/sdio*
Would sm1_s905x3_4g not also be the correct DTB for this model?
CoreELEC:~ # udevadm info /sys/bus/sdio/devices/sdio*
P: /devices/platform/ffe03000.sdio/mmc_host/sdio/sdio:0001/sdio:0001:1
L: 0
E: DEVPATH=/devices/platform/ffe03000.sdio/mmc_host/sdio/sdio:0001/sdio:0001:1
E: SDIO_CLASS=07
E: SDIO_ID=024C:C821
E: MODALIAS=sdio:c07v024CdC821
E: SUBSYSTEM=sdio
Yes, I tried it, but with that he didn’t even give a video
So maybe a box with a fake amount of RAM.
Looks like you have a RTL8821CS WiFi/BT combo.
The RTL8821CU seems supported but I see no mention of the CS variety but I’m sure that the CE team will confirm.
