I am using Odroid N2+ with CoreElec v20.1 and PVR-Client “IPTV Simple Client v 20.10.0.1”. My own m3u channellist worked great with an online “easyepg-basic.gz” and its URL.
Since some time (not sure, if its since the update to v20.1) the EPG is empty. The URL works fine and the *.gz file is not corrupt. Even the IDs are maching correctly with my m3u file. In the past it worked all great!
I have no idea, why i cant see the EPG infos anymore.
The IPTV Simple Client config shows me three entries. One of them: “Migrated Add-on Config” [AKtiviert] bearbeiten".
Any idea how to fix / what was changed? thx
This is one of the most important functions for me to watch and select tv program.
What do you mean by saying “make proper kodi debug log which doesn’t crash”? I tried to create log files (faq way) and uploaded the files? so what’s wrong?
OMG, it works again and i’m really really happy that you found and solve the problem !!
I looked at the rytecDE_Basic.gz file too but did not noticed the wrong date range of the entries.
So many many thanks for your amazing help/support!
Let this be a lesson to others that good log file is the only way to help with issues happen only by user itself.
When others can replicate the issue it is always easier to solve them.
