Dear friends,
I installed CoreElec 22.0 on SD with the right display configuration file vfd.conf and everything works fine. I would like to know if it is possible to lower the display brightness a bit. I disabled OpenVFD because it gave an error. Is there perhaps a change to some parameter in the vfd.conf file to change the display brightness…? Thank you.
Welcome to CoreELEC
Reinstall Open VFD, make sure you are on Expert Settings.
The default setting for brightness is 7,i have set mine to 0.
The difference is quite noticeable
After you change parameters in Open VFD
Reboot to apply changes
This is the only way i know how to do it.Does nit mean there is no other way
