I have 2 instances of HTSP client for tvheadend on my Kiii Pro with CoreELEC 9.2.1.
The first is accessing a tvheadend server on a NAS, this one works without problems.
The second accesses the local tvheadend server, which records to a USB HDD.
Some times it seems to loose the connection to the tvheadend server, it doesn’t show me the channels and the recordings.
This happens most of the time when I pause a recording and the resume.
If I disable and enable the plugin, then it works again.
Is there a work-around for this?
Best regards
Andy
