Hi all, i have a Minix U1 (s905) with last stable CE. I attached a usb adapter Avermedia volar Black. Installed Tvheadend, in the page adapter the list is empty.
the result of dmesg:
[ 16.176116@0] kernel-overlays-setup: processing conf /storage/.cache/kernel-overlays/50-driver.dvb.crazycat_aml.conf
[ 16.212611@0] kernel-overlays-setup: added modules from /usr/lib/kernel-overlays/driver.dvb.crazycat_aml/lib/modules/3.14.29
[ 19.825924@2] usb 1-1.3: dvb_usb_v2: found a ‘AverMedia AVerTV Volar Black HD (A850)’ in cold state
[ 19.832792@2] usb 1-1.3: dvb_usb_v2: downloading firmware from file ‘dvb-usb-af9015.fw’
[ 19.933248@2] usb 1-1.3: dvb_usb_v2: found a ‘AverMedia AVerTV Volar Black HD (A850)’ in warm state
[ 20.327495@2] usb 1-1.3: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
[ 20.327544@2] dvbdev: DVB: registering new adapter (AverMedia AVerTV Volar Black HD (A850))
[ 20.328534@2] dvbdev: dvb_create_media_entity: media entity ‘dvb-demux’ registered.
[ 20.341552@1] usbcore: registered new interface driver dvb_usb_af9015
and lsusb:
Bus 001 Device 004: ID 07ca:850a AVerMedia Technologies, Inc. AverTV Volar Black HD (A850)
Bus 001 Device 003: ID 1997:0409
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
The driver of adapter seem correctly installed, but nothing detected from Tvh…
In folder /dev don’t exist dvb.
Thanks in advance for suggestion.
