So I have been running the nightly version of Tvheadend, which has been working for days on libreelec without reboot.
Since moving to coreelec, it works on the initial run and then overnight after maybe 12 hours or so the process for tvheadend doesn’t exist anymore. Naturally i go to disable the addon and re-enable, restart the box and nothing seems to get it working. The only thing that can start tvheadend is to re install the add on, which then it works for a part of the day again and it stops again.
I put the tvheadend log on “all” for trace so cant upload the full amount, but here is the last 1000 lines of it
And here is the debug log from kodi
