I recently bought a TX3 mini. CE boots fine on it, both the mainline and the NG version. But 2 things are lacking: WIFI and the VFD display. I checked with dmesg and saw that neither are loaded by the kernel. So, probably the drivers are missing.
Yep, I know the TX3 mini is supported and yes, that’s the config I’m using. But my point is that apparently the TX3 I recently bought has different components inside. That’s why I posted the info about the wifi chipset and the vfd display.
BTW, I also own a TX3 (maxi?) with the S905X3 soc, 4b, 32gb emmc and that one works perfectly, inlcuding wifi and the display.
For VFD, you’ll have to boot Android, run Terminal and execute the following command: cat /sys/kernel/debug/gpio
Then post a screenshot\picture of the output.
No luck there either. I already installed CE to the EMMC. But to give it try I downloaded Android 9 for the TX3 mini and installed that. Unfortunately the display didn’t turn up and here also: no wifi support.
But now I have a new problem: how to re-install CE? The usual method of booting from u-SD (and using the button on the back) does not work anymore: instead, I end up in the Android recovery screen. Ho hum. Any idea how to solve this??
Ah, finally some progress. I downloaded the Android firmware from Geekbuying where I’d ordered the TX Mini. After installing that with the Amlogic burning tool I was able to boot CE again.
What’s strange though: after installing Android there was still no wifi support and the display didn’t work either. I suspect, as said this model uses, different hardware and apparently the stock Android firmware is for the older/other version.
Excellent. Glad you got it at least partially working. Good of Tanix to keep end users guessing with a healthy array of offerings from the Shenzhen market.
I managed to get my hands on a second TX3 mini with a working Android install, so now I can investigate further. For the VFD I’ll add a post to the VFD thread. And I already added a post about the wifi chip in “Looking for users with no working WiFi or BT” thread.
