I have two TX9 PRO. In the “old”, Coreelec works perfectly.
The last time I bought it, the wired network is down.
I photographed the two motherboards, the new one on the right.
How about telling us what dtb.img you’re using or what you’ve tried or what worked with the old one that works.?
Disclose your SOC too.
I can’t be bothred looking it up.
TX whatever means nothing to me.
Please disclose your harware specs.
I cant see what’s under that heat sink.
