i just bought a new tx92-lp 3g/32g box. i used the q201-1g dtb. i works pretty great except ethernet speed is kinda slow im getting about 490Mb down and about 90Mb up. when i boot to android i get 900/900. i tried a couple different dtbs but got same speeds. any help would be great. thanks
How are you measuring the speed what protocol ? Are you using it as a server 490Mb down is fast enough even for the biggest bitrate HDR file.
im sure you are correct that it is fast enough. i was just trying to find out if this is a known issue or if maybe there was a work around to get full gigabit ethernet speed. thanks
You used the command line version in CE and in android?
Ah I see there is an addon.
SSH into your box and run the following command in CE.
curl -s https://raw.githubusercontent.com/sivel/speedtest-cli/master/speedtest.py | python -
Using iperf (it’s part of the network-tools addon) is a much more accurate way of testing the network throughput of your box.
In addition, cheap Chinese Android boxes often use sub-par components that either require very specific drivers or non-standard configurations to work at full capacity, it’s almost impossible for us to get all available devices to work at their full network speed due to this variance.
Using iperf on my TX92 with CE 9.0.1 I’m getting over 900Mbps in both directions.
running that command gave me 750/350. more than good enough for me.
thanks for everyones help. i tried iperf but couldnt figure it out
On my side I don’t see any issue with ethernet speed
tx92-salon:~ # iperf3 -c 192.168.28.1 -t 10 -p 5201 Connecting to host 192.168.28.1, port 5201 [ 5] local 192.168.28.82 port 47106 connected to 192.168.28.1 port 5201 [ ID] Interval Transfer Bitrate Retr Cwnd [ 5] 0.00-1.00 sec 108 MBytes 907 Mbits/sec 10 120 KBytes [ 5] 1.00-2.00 sec 108 MBytes 905 Mbits/sec 7 86.3 KBytes [ 5] 2.00-3.00 sec 103 MBytes 865 Mbits/sec 4 112 KBytes [ 5] 3.00-4.00 sec 104 MBytes 870 Mbits/sec 14 77.8 KBytes [ 5] 4.00-5.00 sec 107 MBytes 896 Mbits/sec 0 126 KBytes [ 5] 5.00-6.00 sec 102 MBytes 853 Mbits/sec 10 76.4 KBytes [ 5] 6.00-7.00 sec 102 MBytes 852 Mbits/sec 4 96.2 KBytes [ 5] 7.00-8.00 sec 102 MBytes 854 Mbits/sec 7 87.7 KBytes [ 5] 8.00-9.00 sec 104 MBytes 868 Mbits/sec 4 107 KBytes [ 5] 9.00-10.00 sec 106 MBytes 887 Mbits/sec 7 84.8 KBytes - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate Retr [ 5] 0.00-10.00 sec 1.02 GBytes 876 Mbits/sec 67 sender [ 5] 0.00-10.04 sec 1.02 GBytes 872 Mbits/sec receiver iperf Done. tx92-salon:~ # uname -a Linux tx92-salon 3.14.29 #1 SMP Tue Sep 7 08:30:05 CEST 2021 aarch64 GNU/Linux tx92-salon:~ # lsb_release -a CoreELEC (official): 9.2.8 tx92-salon:~ #
