Ugoos AM6 Plus and eMMC
It possible that you could restore 0.3.7 Android image(if possible) via cable and Amlogic Burning Tools and try again with ceemmc
According to @Maat236 (quoting Ugoos), no. But anyway, I’ll probably invest into a fast SD card (Ugoos claims UHS-II compliance, which should be plenty fast) unless someone comes along with a better solution.
Thanks again, both of you.
Ok, I will ask Ugoos tomorrow.
And may be I’m wrong and 0.3.6 is last not encrypted.
Thanks. Did you get a reply or other relevant information about this issue?
I also think if the encrypt it now we can safe remove the dtb for Ugoos…
@maha, they have encrypted firmware since 0.3.7 version and firmware still in development…
Ugoos representative informed. Now I’m waiting the answer if they could fix the system for our ceemmc installation.
@Portisch, normal installation on USB/SD works, only internal via ceemmc is temporary broken if they have 0.3.7 - 0.3.9.1 Android versions.
