I just received my new Ugoos AM6 Plus and put CoreELEC into an micro-sd card.
I can boot into the micro-sd card with CoreELEC and Kodi GUI is working.
However I can’t make the Ugoos remote working with CoreELEC.
This is the remote I have:
What can I do to fix this?
If you have the same hardware, did you manage to make it work?
Do you think I would have better luck with the official dual-boot firmware from the Ugoos team?
I would switch to a Bluetooth or rf remote as they are much more responsive. I’m using the minix remote and harmony hub Bluetooth. You will love not having to point.
I already have some old RF remotes from previous devices, but it should be great to make this device plug and play with CoreELEC.
I would like to know if someone else makes it working and if not what could I do to make it working (mapping each button manually?).
Yes, automated detection is indeed not possible, and also not worth the effort in case there is only one file to copy to the right place.
But maybe it would be possible in future to extend the DL helper, to point to the right remote file for the selected box.
