Ugoos AM6 Pro vs Ugoos AM6 Plus (or Odroid N2)?
Hi there
So I’m torn between Ugoos AM6 Pro vs Ugoos AM6 Plus. I need CE to run from eMMC and Android from uSD OR both from eMMC if possible.
From what I know, the difference between above two is that Plus version has S922X-J 2.2 GHz CPU and Dolby Vision support vs S922X-H 1.8 GHz in Pro model and no Dolby Vision support.
Difference in price is around $15 so no big deal.
So my question is. Can I use images downloaded here - for Regular-Non-Pro or Pro ver. to use them in Plus Version? Will they work?
As a sidenote.
At first I also thought of buying Odroid N2 - but this developer board might be to much hassle for me. Now, I need box with very good WiFi - I do not have cables where I’ll put the device. I heard that WiFi dongle (5A) for Odroid N2 is not so good.
I also need remote support out of the box (Logitech Harmony via IR). Can I do that with Odroid N2?
What would you choose?
Ugoos AM6 (Pro, Plus) or Odroid N2. Here in Poland, Odroid N2 set would costs me around $195 while Ugoos Pro, Plus - around $135 - $140.
any test for CE & S922X-J ?
I second that question. Is there any significant difference between S922X and S922X-J that would prevent the CE from running on S922X-J?
Look what U can have here:
Both sysrtems on eMMC. No SD card. :slight_smile:
Support Ugoos Said:
AM6 Plus support CoreElec with wifi,ethernet and BT
CPU s922x-j supports dolby vision, Amlogic supports coreelec
The fact that CPU supports Dolby Vision does not mean software will support it, As far as I know, DV currently works only for streaming. Neither Android apps, not CE can run DV files from LAN or HDD
Hi, how about now in 2025 with FEL files? Any reason to change to Ugoos AM6+?
Now I have Ugoos AM6 Pro version.
Thanks!
