UGOOS AM6B 20.3-Nexus Dolby Vision doesn't activate correctly
Dolby Vision doesn’t activate correctly, it only maps to HDR and there’s no Dolby setting in the video settings
Using username “root”.
CoreELEC
https://coreelec.org
CoreELEC (official): 20.3-Nexus_nightly_20230905 (Amlogic-ng.arm)
Machine model: UGOOS AM6B
CoreELEC dt-id: g12b_s922x_ugoos_am6b
Amlogic dt-id: g12b_AM6b_b4g
CoreELEC:~ # journalctl -l | paste
http://ix.io/4FwM
CoreELEC:~ # dmesg | paste
http://ix.io/4FwN
CoreELEC:~ # ce-debug
http://ix.io/4FwO
CoreELEC:~ # fw_printenv | paste
http://ix.io/4FwP
CoreELEC:~ # systemctl status opentee_linuxdriver.service -l --no-pager
● opentee_linuxdriver.service - Optee TEE-Supplicant and Video Firmware Preload service
     Loaded: loaded (/usr/lib/systemd/system/opentee_linuxdriver.service; disabled; preset: disabled)
     Active: active (exited) since Wed 2023-09-06 20:09:31 CST; 41min ago
    Process: 3373 ExecStart=/usr/lib/coreelec/tee-loader start (code=exited, status=0/SUCCESS)
    Process: 3401 ExecStart=/usr/lib/coreelec/dovi-loader start (code=exited, status=0/SUCCESS)
   Main PID: 3401 (code=exited, status=0/SUCCESS)
Sep 06 20:09:31 CoreELEC tee-loader[3373]: tee not needed (SoC is less than SC2 (0x32) architecture)
Sep 06 20:09:31 CoreELEC dovi-loader[3401]: run dovi 'start' for ng
Sep 06 20:09:31 CoreELEC dovi-loader[3401]: loading dovi module
Sep 06 20:09:31 CoreELEC dovi-loader[3446]: filename:       /android/vendor/lib/modules/dovi.ko
Sep 06 20:09:31 CoreELEC dovi-loader[3446]: license:        GPL
Sep 06 20:09:31 CoreELEC dovi-loader[3446]: description:    Amlogic Dolby Vision Driver
Sep 06 20:09:31 CoreELEC dovi-loader[3446]: depends:
Sep 06 20:09:31 CoreELEC dovi-loader[3446]: vermagic:       4.9.y SMP preempt mod_unload modversions ARMv7
Sep 06 20:09:31 CoreELEC dovi-loader[3450]: insmod: ERROR: could not insert module /android/vendor/lib/modules/dovi.ko: Invalid module format
Sep 06 20:09:31 CoreELEC systemd[1]: Finished opentee_linuxdriver.service.
My device is ugoos am6b plus 2021, and the system is corelec 21 alpha2 ng-dv. I have found two bugs so far: one is that the bluetooth remote needs to be re-paired after powering off the device, and the other is that the dolby vision is only working properly on some mp4 videos, and other mkv video formats are not playing properly.And, coreelec backup data cannot be restored.
The Dolby Vision version of corelec 20 ng-dv can also be activated, but it cannot be mapped normally
CoreELEC (official): 21.0-Omega_alpha2 (Amlogic-ng-dv.arm)
http://ix.io/4EP4
http://ix.io/4EP5
http://ix.io/4EP6
http://ix.io/4EOR
     Active: active (exited) since Tue 2023-08-29 19:10:32 CST; 19min ago
   Main PID: 3303 (code=exited, status=0/SUCCESS)
Aug 29 19:10:32 CoreELEC systemd[1]: Starting opentee_linuxdriver.service...
Aug 29 19:10:32 CoreELEC tee-loader[3275]: tee not needed (SoC is less than SC2 (0x32) architecture)
Aug 29 19:10:32 CoreELEC dovi-loader[3303]: run start for ng
Aug 29 19:10:32 CoreELEC dovi-loader[3303]: loading dovi module
Aug 29 19:10:32 CoreELEC dovi-loader[3329]: filename:       /android/vendor/lib/modules/dovi.ko
Aug 29 19:10:32 CoreELEC dovi-loader[3329]: license:        GPL
Aug 29 19:10:32 CoreELEC dovi-loader[3329]: description:    Amlogic Dolby Vision Driver
Aug 29 19:10:32 CoreELEC dovi-loader[3329]: depends:
Aug 29 19:10:32 CoreELEC dovi-loader[3329]: vermagic:       4.9.y SMP preempt mod_unload modversions ARMv7
Aug 29 19:10:32 CoreELEC systemd[1]: Finished opentee_linuxdriver.service.
Use “Amlogic-ng-dv”!
There does no nightly exist yet. Use CE-21 Amlogic-ng-dv until 20.3 release.
Thanks.CE-20.3 Amlogic-ng-dv 2023.08.09 or Use CE-21 Amlogic-ng-dv can only light up the Dolby field of view, but cannot map colors properly, as reported above.
It is said that CE-21 Amlogic ng dv has stopped updating?
Is the 922x-j chip rebuilding the NE kernel?
Is Amlogic-ng-dv and Amlogic-ng merging?
