Anyone know where to buy this cable ? I have tried to use a usb c to usb a cable (which works with my phone) but that didn’t work.
I need to reflash my device with the 0.5.4N firmware that ugoos sent me
kind regards
Svein
kind regards
Svein
any cable USB-C to type A or c will work, I used my mobile cable type-C to type-C and I flashed slimBOXtv version Android in am6b+.
Since there is no USB-C port on AM6B+ which adapter did you use for C to A?
Which SlimBOX version? This one → “Ugoos AM6, PRO, Plus, revision B”, ATV or AOSP?
How does it work for you?
I have tried 2 different cables now, both usb c to usb a. usb c connected in my pc and usb a in the ugoos. Both cables boot into the android recovery menu. I also have a am8 pro with usb c as otg port and it worked with reflashing firmware wit a usb c to usb c cable.
I know there isn’t typ-c in am6b only type A, I meant in my laptop output usb-c TO am6b type A, regarding slimbox I installed ATV version but now I only use CE into ceemmc.
Please, could you share the 0.5.4N firmware? Mine’s stuck at the boot screen when I tried to flash 0.5.4 on my UGOOS AM6B+
This may help you.
