Ugoos AM6B+ supplied HDMI cable
Hi, does anyone know if the supplied HDMI cable with the Ugoos is 2.0 or 2.1 ?
Hi, it’s a regular cable HDMI high speed with ethernet. Probably certified for HDMI 2.0, it doesn’t mean it can’t pass HDMI 2.1 signals though. There’s no physical difference between an HDMI 2.0 capable and 2.1 capable, just the quality of the wiring and connections. Some cables are certified 2.1 and that’s the only way to know for sure it will pass HDMI 2.1 bandwidth.
I have no issues with Dolby Vision 4k etc. using 10+ year old cables.
If you get black screen issue with 25 fps movies, you can replace the supplied HDMI cable for a test.
I got such annoying issue and after one and half days troubleshooting I fixed it by replacing the cable.
