I have a UGOOS AM8 Pro with the S928X-J processor and 8 GB RAM, running CoreELEC 22 (Piers).
System information:
Device: UGOOS AM8 Pro S928X-J (8 GB)
CoreELEC: 22 (Piers)
Kernel: Linux 5.15.196
Architecture: aarch64
Booting CoreELEC from a microSD card. Android 11 remains installed on internal storage.
Problem:
The USB-A ports do not reliably detect external storage devices.
I have tested:
WD My Passport SSD 500 GB, using its original cable.
A second external USB hard drive.
A USB flash drive, which initially worked but was not detected in a later test.
The WD SSD works perfectly in Android 11 on the same UGOOS device, using the same cable.
It is also detected and mounted correctly in CoreELEC when connected through a multiport USB-C adapter. The SSD appears as:
1058:264f Western Digital Technologies, Inc. My Passport 264F
And lsblk shows:
sda1 465.7G /var/media/My Passport
However, when connected directly to the USB-A ports, it is not reliably detected.
Relevant kernel messages when connecting the SSD directly:
usb 4-1.2: reset SuperSpeed USB device number 3 using xhci-hcd-meson
xhci-hcd-meson xhci-hcd-meson.2.auto: ##### crg set max_burst 0
usb 4-1.2: USB disconnect, device number 3
sd 0:0:0:0: [sda] Stopping disk
sd 0:0:0:0: [sda] Start/Stop Unit failed
I have also tried different USB-A ports and different cables, including an older cable, without success.
The USB-C adapter works correctly with both the wireless mouse receiver and the WD SSD connected simultaneously.
My questions:
Is this a known USB 3.0 / xHCI controller issue with the S928X-J and CoreELEC 22?
Is there a known workaround, driver fix or device-tree adjustment?
Is there any additional diagnostic information I can provide to help identify the problem?
I would appreciate any help in getting the USB-A ports working correctly in CoreELEC.
Thank you.
