Still working like before… no error or bug!
But no sample was provided so I am sure it’s user fault!
Could you try this video?
Did see the green screen also after resume from standby. It happen with every video playback.
Maybe new kernel will fix it…
Edit:
New kernel does not fix it. Also the non pro version shows same effect. It’s a GPU valhall power issue.
But only visible on HDR screen. On SDR all looks normal.
Pardon the interruption, where did thus test file come from?
Tested on X96X10 S928X-J in both playerLED and TV LED there are over 1500 skipped frames, yet 0 frames dropped colors are brilliant/ vivid, no real issues with playback.
Just seems our of order???
I think I downloaded it two years ago
The file name indicates where it was downloaded from.
Ok ,I see the tag from where download
Still must be a glitch 994 skips in 52 secs of playback …
Has lastest Nightly fixed green screen issues ![]()
Don’t enable GUI and you will get no skip frames
