Hi guys. I installed my tvbox behind the TV, but the problem is that I can’t connect additional power to it, because I no longer have 220 volt sockets available. Also, I have an xbox series s installed near the TV. I was thinking of powering the tvbox from the xbox usb port. The problem is that the native tvbox power supply is ~2.5A, and the xbox with a usb port is 900mA maximum. Will this power supply be enough for the tvbox? I tried to find the datasheet on the s905x2 to clarify the power consumption, but I couldn’t find it.
No
You need to use adapter that came with tv box
After thought
Maybe buy a power strip with surge protection
Then TV xbox and ugoos are all protected
Happy Testing
As a result, I powered my x2cube from the xbox usb port, and I don’t see any problems. Tvbox works stably. I have conducted several stress tests using sterss-ng combining it with iperf.
Very good
Have been reading a little about this.
X box usb port is always powered/even when x box is off.
You have almost 1 amp from x box…
You are using which type usb cable?
To otg port on ugoos?
I see there are usb to barrel jack cables.
I would still recommend power strip with surge protection!!!.
Happy Testing
I used a cheap short (20cm) UsbA-Usb micro cable.
Okay
This is my opinion only
Stressing all cores and ram through computations is not the same as steaming 4K/Video playback/youtube etc…
Where only one or 2 cores do all the work and other’s sit idle…
Random reboots from loss of power etc…
There is a reason for power supply rated ar 2.5 amp
Hopefully you never have issues
And all is good
Happy Testing
