Installed coreelec on a SD card and booting from it. Al works perfectly but i have come across some files which shows a black screen but the audio plays.
When i check it on my PC with VLC it give this info:
Decoded format: Planar 4:2:0 YUV 12-bit LE
Color primaries: ITU-R BT.709
is there a way i can fix this. i think this chip should be able to play it.
