Hi.
I am using Core-Elec 20.5 on a N2+ and I have a Mini-X remote. I had the IR wake working some years ago and now I want it working again. When I in Kodi go to system/hardware and under Power choose “Ir Remote Power Code” and change it to MiniX it does so, but as soon as I leave hardware and return to hardware it is not set anymore, thus not working. Why won’t hardware save?
The same goes for the other settings in Hardware.
Ok, I could be mistaken but I have a very similar setup and this what I would suggest:
- set desired settings in hardware section
-back out of menu’s to the home screen
-popup would say reboot required
-reboot
Try it and check settings after reboot
Hi Atreyu.
Thank you for reaching to help. ![:slight_smile: :slight_smile:](https://discourse.coreelec.org/images/emoji/twitter/slight_smile.png?v=12)
There is no pop-up. It seems like my changes are just instantly forgotten?
That’s odd. I always get a ‘reboot now’ popup after changing these settings. I guess that’s because it seems to set the value(s) on reboot in some config file.
What happens if you change the ir code and immediately reboot ?
