Hi, how can i create an auto restart CoreElec script? Thanks for help.
Not reboot, i need restart kodi
[Unit]
Description=CoreElec
After=network.target
[Install]
WantedBy=multi-user.target
[Service]
Type=simple
RestartSec=5s
[Unit]
[Install]
[Service]
Type=simple
RestartSec=5s
You could tell us why do you even need this?
Why is restart needed? If you need to delay it for some reason add sleep command to /storage/.config/autostart.sh file
Sometimes an addon is not started. How do I do with autostart.sh?
First you should try to enable “wait for network” in coreelec settings.
If this still doesn’t help add command to the autostart.sh file.
sleep 5
sleep 5
Is that correct?
No, just sleep 5. Adding ()& puts command in background and it will not do anything in this case.
Can an example be given?
Try
echo “sleep 5” >> /storage/.config/autostart.sh
is not working…
Then try with larger value.
But you should identify the problem first: why addon doesn’t start. Check kodi.log with debug enabled.
Is there any way to wait for the adon to close and then CoreElec to close? Is such a thing possible with shudown.sh?
Proper addons are closed properly.
Seems you don’t want to provide any useful information so I’m out.
Banned addon -> elementum
No support
ok, thanks for help
