Unsecure Network Random Actions On its Own
Hi seriously worried as possible network breach.
Recently my Coreelec GS king-X(on @doppingkoala https://discourse.coreelec.org/t/learning-about-dolby-vision-and-coreelec-development/50998/606 performs random actions on its own i.e open tabs, asking for master lock without me pressing anything. Is like someone outside my network always accessing my system.
Running bunch of dockers incl Transmission daemon, plex server. And my Transmission has unsecured message even though i set a rpc password.
What type of logs will show the root cause of this?
Any help with this, is scary how this is happening. Anyone has random addons actions opens & master lock dialog open . What logs will see where is this coming from?
You must have some strange addon installed.
Reset CE and start from scratch.
It mostly happens when i turn on upnp/dlna. Still observing i just wish there’s a way to track it bia logs or something.
Maybe CE is DLNA server and some client controls it?
Possibly , any way to track the clients , thanks .
Maybe in kodi log file?
Thanks Where is the log located?
In CoreELEC settings
System
Submit Log
Also in Kodi repository there are 2 addons that are quite useful
Log Viewer for Kodi
Kodi Logfile Uploader
Also in UPnP settings, have you somehow enabled
Allow remote control via UPnP ?
Or this settings has to be enabled for this to work?
Thanks, will look to get logs
I suspect this, after i turned it off, it reduced. And I get file folders created on its own in video-files with the name ‘plexkodiconnect hack’ & opening it has access to my system with the ip address.
I do not test plex/PM4K/plexservor
You are sharing your library with all clients
Assume you have permission set to access system/library
Maybe it is just the addon scanning/ updating
