Hi all, the update info screen keeps popping up on every boot of all my 4 machines? how to stop it?
Which update info? A screenshot would help identify what you need to do.
should only pop up once, are the boxes doing a full reboot?
Matt
The info box after an update, that tells you whats new, i click back, and it just comes up every time, yes im rebooting the boxes, only comes back after a power off.
Anyone?
Reboot the box manually from the menu and it will stop.
From what menu?
Had a shortcut on my homescreen called reboot, that worked.
? The power menu in Kodi.
