hmm booted, and then theres a splash screen saying
v18 LEIA BETA
Addon Migration running … please wait
How long will this last?
Its running 20 min plus currently…
any help? wait or is there something wrong?
v18 LEIA BETA
A similar situation happened to me where some package failed to download. There are few similar situations mentioned 8.95.5 release thread.
I would probably just reboot via SSH if it doesn’t seem to go further otherwise.
ok cut the power and started the box again.
kodi started with my old choosen skin AEON NOX and seems to work.
a notification popped up which says COREELEC update available.
how to handle this information?
Which version are you on now? 8.95.5 is the newest, maybe you had an old update from previously which you hadn’t installed.
its 8.95.4.3 currently
how to get it easy updated?
Probably your update notification is for 8.95.5 which is the latest version. I would just reboot again and let it install. Hopefully you won’t get stuck at the addon migration process screen again. Keeping fingers crossed.
thanks to you all for your help.
did a reboot and update is done.
thanks so far.
all libs and settings seems also to be installed from the backup which i have stopped with a power cut off as well.
so saturday evening is secured
Hey,
my box updated to 8.95.6b and now the remote is not working correct.
how can i fix that? i downloaded your files and checked the sd card but i cant find any dir on the sd card to copy the files from your link.
Can you please help me?
I had the same probelm, you need to read the release notes
CoreELEC 8.95.6 is now available and can be downloaded from our GitHub page here.
** Following these changes we have had to remove out of the box support for the following IR remotes,
A95X, MeCool, MINIX.
If you are using a device with one of the above IR remotes you can re-enable support by executing
the corresponding command below via SSH and rebooting.
echo "meson-ir * a95x" > /storage/.config/rc_maps.cfg
echo "meson-ir * mecool" > /storage/.config/rc_maps.cfg
echo "meson-ir * minix_neo" > /storage/.config/rc_maps.cfg
That means for me, connecting via ssh and use this command:
echo “meson-ir * mecool” > /storage/.config/rc_maps.cfg
nothing else?
Yes, then reboot. it worked for me
how to ssh on theb ox.
is it root / coreelec?
yes, it is root coreelec
ssh 192.168.0.49 -l root
root@192.168.0.49’s password:
Permission denied, please try again.
I don’t know how you used it.
I open putty, my settings are there, ie ip address ( I can’t remember how)
then connect, a terminal window opens, I log in as root, it then asks for a password.
I would send a screenshot but I don’t know how to
found this here
coreelec is not working as pass
If you updated to CoreELEC over a LibreELEC install at some point in the past on that device the password might still be “libreeelec” since the update process does not change passwords.
have you gone from a libreelec build to coreelec? or a clean install of coreelec
try libreelec
WTF
now i cant enter anything when ssh over TERMINAL with my mac:
root@192.168.0.49: Permission denied (publickey,keyboard-interactive).
any . idea?
Is ssh turned on in the settings?
